Headlights won't come on ???
Discussion in 'Interior/Electronics' started by 22R88, Aug 22, 2010.
  1. 22R88
    22R88 Veteran
    South Louisiana
    1988 Reg Cab Deluxe RN50
    The lights don't work consistantly. I assume the switch on the wheel is bad. Do I have to go to a dealer to get this or can I take it apart and clean the contacts ?? any advice appreciated ..
    Thanks,
    22R88
  2. 22R_All_Motor!
    22R_All_Motor! Addict
    Houstone
    84 pickup
    what year is your toyota?
    check your relay... it may be going bad....
  3. 22R88
    22R88 Veteran
    South Louisiana
    Thanks for the reply. It is a 1988. Reg Cab 2WD DLX Where is the relay ? How do I check it ?
    Thanks
    22R88
  4. 22R_All_Motor!
    Houstone
    84 pickup
    well, it's by the battery, but i just went outside to check and didn;t find one... either because my sticker is broken on the box or it doesnt have one or hmm... lol.. maybe it's under the dash... i'll look into it... if not, i have a spare switch.... i'll look into it.... :waytogo:
    *edit*
    ok i just looked up on alldata and it's by the battery for the 88 model year... i suppose it's different for mines? idk.. wtvr... it's up there for yours...
  5. 22R88
    22R88 Veteran
    South Louisiana
    Thanks for the heads up, I'll look into it. If I need the switch how much do you want for it ?
    22R88
  6. 22R_All_Motor!
    Houstone
    84 pickup
    idk, $30 + your shipping method??
  7. 22R88
    22R88 Veteran
    South Louisiana
    How do you check the relay to know if it is it or the switch ?
    22R88
  8. 22R_All_Motor!
    Houstone
    84 pickup
    try using the ac relay for it...
  9. 22R88
    22R88 Veteran
    South Louisiana
    OK. I pulled the relay while the high beams were on and they went out. Low beams won't come on at all anymore, high beams are hit and miss when I have someone turn the switch I feel the relay click. Can the relay be bad on low beams only or is a relay just good or bad ? I am thinking that the switch on the columm is the problem ???
    Thanks
    22R88
  10. TP88
    TP88 Enthusiast
    ontario cali
    1988 toyota pickup singl-cab
    happen to me
    same prob i had just not to long ago well it sounds like it try moveing around the wireing under ur steering colom the on that gose to ur left and right,hazerds,wipers and all that and at the same time turn ur lights on and off see if they will work this work for me but for me it was my high bems that were doing that if u find out find the spot were they will stay on and (i ziptied myn) u can zip them up or find a way to have them not move or tape them up let me no how it gose
  11. 22R88
    22R88 Veteran
    South Louisiana
    Turned out to be a bad dimmer switch. Had to remove wheel and take blinker/ dimmer / wiper assbly out and extricate switch to replace.
    Thanks,
    22R88
