Header
Discussion in 'Engine/Drivetrain' started by IBeSeeN, Oct 6, 2008.
  1. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
  2. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    the non emissions header is hard to find.
    that looks like the standard cheapie header. imho its doug thorely or nothing.
    they were badged TRD back in the day. there is one on ebay right now non emissions TRD doug thorley.
  3. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    X10 on the DT header!;)
  4. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    That is a Pace Setter header. Stay away from them. They are made out of very cheap thin metal. Buy a Downey or an LC Engineering one.
    James
  5. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    ok so basicly the only real options are downy, Doug Thorley, or LC? or do they sell like a header kit that u can build like they do for small block chevy's?
    and the best place to get EGR Block off plates is LC?
    and i guess it dosen't have to be non emissions i could make it that way i work in a welding shop
  6. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    best place for egr block off plates is your garage
    if you work in a welding shop, you could make your own header with half a kit from a 350. just need to make the flange.
    LC resells headers... mostly DT's.
  7. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Pace Setter headers suck!!!
  8. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    whys that ? seam cost effective and better than stock to me...
  9. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    they have dinky lil flanges, welds suck. and they arnt any better flowing then the stock manifold.
    in fact i threw mine away cuz it devolped a leak in the center of the collector after a few years. switched to the late 22r manifold (tri-y type) and noticed a power boost, and the eng is much happier at higher revs.
    ANY header is not a upgrade.
  10. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Agree!! I had one on my 88 Toyota with the 22R & from the start it did nothing but leak & as for performance it did nothing to help out. Pay more for a good header & youll be alot happier in the end.
  11. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    LC,or Doug Thorley,are the only ones to use!! LC's are stainless steel!:cool:
  12. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    LC's FTW, they are stainless and coated!!!!
  13. 2low4you
    2low4you Newbie
    carb
    i am in need of carb. for a 77 toyota 20r motor
  14. oldskulux
    oldskulux Newbie
    red bluff ca
    76 yota mini
    weber makes awsome carbs for 20rs as for the header i had a hooker header on my 20r dont see why they wouldnt make one for the 22r of you can stick a 20r head on your 22r and make it have a better compression ratio and more hp plus u can get the hooker header for it
  15. Twisted Minis
    Twisted Minis Addict
    Poor Cal
    1980 Toyota
    I have a Thorley Header. It's pretty nice, but it warped pretty bad right off the bat. I keep tightening it, usually once a month, and the exhaust leak gets a little better. But it just keeps coming back. I really need to resurface it. But next time I will probably try an LC header after Thorley jerked me around after sending the wrong header the first time. That, or make my own with a 1/2" flange.
    I have a stock 78 carb in my garage. I bought it rebuilt, then bought a Weber.
  16. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    the lc is very nice, downey off road also makes a nice one
