Header question?
Discussion in 'Engine/Drivetrain' started by TP88, Jun 19, 2013.
  1. TP88
    TP88 Enthusiast
    ontario cali
    1988 toyota pickup singl-cab
    What is the diff between long tube headers and short headers? Any help looking in to buying some
  2. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Long time consenses long tube full length headers are overall more efficient at using exhaust scavaging And give the broadest of power increase thru the power band . Due to there exceptional flow . At all rpm ranges
    Shorties are a lot like oem exhaust manifolds with large primary's and good flow pepole tend to say they are a mid range and high range header .. The scavaging effect is not as big on shorties because the primaries are short and exhaust pulses don't work together to increase scavaging . Not a bad thing a lot supercharged guys like shorties( v8 guys that is ) they will work just fine on a 22r
    Best advice I can give is no matter wich style you choose there both an improvement over stock it's not just the style of header it's also primary pipe size and collector lengths and patterns . That make good headers ..
    I here obx stainless header fits well and flows ..for cheap .plus it's stainless there are many brands to choose from ...stainless or ceramic will last the longest
    On a side note shorties on my lt1 make no gains at all while long tubes average 25 horses with 3 inch y pipe no cats and a retune ecu ..
  3. kingtacoma951
    kingtacoma951 Addict
    CORONA,CALI
    88 SR5 Xtra Cab
    I always wondered about obx....hmmm might look into that
  4. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    scrub pretty much nailed it.
    made a very noticeable difference in my 3tc corolla when i did their 4-1 header...
    just out of personal preference, i like the 4-1 header design best over the tri-y design. ran em in a couple trucks and never liked em. also, downey used to make THEE best headers too.... i havent run a lce header in a while but i liked downey's over lce... too bad downey went under.
  5. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    I have a pace setter on my truck. It hangs about 1.5" below frame level at the collector, but its close enough to the tire that it rarely drags. But its been lots of rarelys over 5 years lol. I think I ordered one for a 4wd 80 though. My cousin had a celica header on his truck, had to mod the collector a bit to clear the firewall.
    The reason I got a pace setter was it was one of the cheaper 4-1s. But it had the largest primaries of all that I found. 1-5/8" primaries and a 2.5" collector. 20r and 22r engines make tons of torque, so don't worry about any potential loses by swapping to one. Shifting the powerband higher helps with launches and getting traction from a stop.
  6. SD YOTA
    yea... downey's had a 1-5/8 primary as well... but they were street legal too.
    i think lce since then upgraded to the same size primaries and collectors.
  7. standardbyker88
    lynnwood, wa
    street legal only matters in cali. lol
  8. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    I'm kinda waiting on someone to bite the bullet and order this obx stainless .. The celiac guys seem to praise it .as it is a copy of LC header .. And have seen and watch obx grow from a eBay Honda header into a competitive company now . Even the v8 rwd cars are waiting on back orders for these things now that would have been unheard of 5 years ago ... If didn't already have a header I'd get one . Cause price is just right for stainless
  9. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Another factor with headers long/ short tubes is to get the most out of headers they should be equal length tubes,the reason there are long tube headers!! Each tube must be the same length!!:cool:
  10. SD YOTA
    huh.... i should check and see if they make any for the 3vz :lol:
  11. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    so long stack headers r much..what size pipe should I run w a long stack
  12. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    A tube size of 2.5'' would be what I would & do use!:cool:
  13. NotAvailable
    NotAvailable Addict
    I think nashman had some headers on his 3vz. Its in his buikd thread but has pics of his other builds I think.
  14. SD YOTA
    yea... i know the stock 3vz and 5vz for that matter is horribly designed to run behind the motor creating a seriously hot engine bay area back there... downey, (back in the day) and LCE run them down with a long tube setup and a Y pipe connector down stream...
    its a nice setup but they still ran around 500-700 depending on who you got em through... its a pricey upgrade but ive been told the gains are pretty significant...
  15. TP88
    TP88 Enthusiast
    ontario cali
    alright buys so I im kinda thinking of going with the obx headers I think im a get them 2day well order them 2day but ill keep u guys posted for right now just trying 2 get my motor back 2gether also had a question would the would the 90-95 header fit my 88?
  16. TP88
    TP88 Enthusiast
    ontario cali
    bump
  17. SD YOTA
    as far as i know yes they do fit. ive used a newer header on an older motor without issues... the only issue you may run into is the air injection manifold design between some of the years..
  18. standardbyker88
    lynnwood, wa
    I've run lots of mismatched headers. Hangingow has been the worst if the problems. Frame clearance should be the same between the two. I've run 4wd and celica headers on trucks so you should be okay.
  19. TP88
    TP88 Enthusiast
    ontario cali
    @SD YOTA THX that's the only thing that's holding me back from buying them
  20. TP88
    TP88 Enthusiast
    ontario cali
    @standardbyker88 oh ok so then a 22re header will fit and also the celica header 2 what about the
    4wd headers will thos fit no problem?
