header concerns 84 p/u
Discussion in 'Engine/Drivetrain' started by craigdbl, Aug 21, 2011.
  1. craigdbl
    craigdbl Guest
    My next project is to get a muffler.I was thinking of puting on a header @ the same time.Has anyone in the Los Angeles area done this and wiil it pass smog?
  2. jetas
    I think aslong as the O2 sensor is at the collector and not on one of the single pipes it should still read correctly. Now the visual check during smog might be where you have an issue.
  3. pologuy5
    pologuy5 Member
    fullerton c.a
    87 single cab
    I think they have card legil ones but I'm now 100% sure
  4. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    There is a carb legal/ smog legal one for our trucks but it's like $500
  5. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
  6. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Any header that states it is Ca. legal should come with a tag that you put on your firewall.
    Without it you won't pass smog!:cool:
  7. dOBER
    dOBER Member
    It all depends on the smog tech.
    Most that know the 22R should just do the sniffer.
    These engines run so clean i doubt they would say anything
    look poor, dont come looking like u have lots of money, cuz they will want some of it.
  8. craigdbl
    craigdbl Guest
    thanks guys,it will be alittle while to save up for so,I'll keep checking it out.
  9. craigdbl
    craigdbl Guest
    Does anyone in Calif. have a header on thier truck(duh) that is street legal? Can you post pics.I've searched the net and Pacesetter is the only one I've found for my 84. It's a 2 piece for $400 w/the oxg. sensor mount on it.
  10. craigdbl
    craigdbl Guest
    header
    Does anyone in Calif. have a header on thier truck that is street legal? Can you post pics. I've searched the net and Pacesetter is the only one I've found for my 84 automatic. It's a 2 piece for $400 w/the oxg. sensor mount on it. Do you swap it back to stock when it's time to get it smogged?
