header bolts
Discussion in 'Engine/Drivetrain' started by suzuki07, Apr 21, 2010.
  1. suzuki07
    suzuki07 Enthusiast
    baytown, tx
    92 isuzu , 92 yota, 07 suzuki
    i need header bolts. i tryed junck yards but wont sell. they said they go with head. so i was wondering if any of u know were i could get them.:shrug:
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    are you looking for the studs that are attached to the head? if you find a bolt that has the same thread size and diamater you can take it to any auto parts store and they can either order em for ya or they might even stock them..they should be cheap too, maybe a buck each.
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    but make sure you get grade 8 bolts. and install them with some loctite into the head. and then put antiseize on the threads of the nuts when you install it. with lock washers. header leaks can be a big pain in the butt.
  4. jetas
    If your talking about the studs for the header then just find a 3vze and pull those off. Theyre a bit longer so u have a lil extra bite. And u can use a 7mm socket to take em out.
    I went thru this a month or 2 back. I still have some left
  5. suzuki07
    suzuki07 Enthusiast
    baytown, tx
    i found them on ebay but they go for $56 what you all think?
  6. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
    I bought a set of studs today from ACE for $1.20 a piece. The bolts are 10mm x 1.25, and I think the length is 125 (if i remember right). There are 5 studs total. I picked up 5 hardened bolts ($0.64 each) and 9 lock washers ($0.13 each). The other bolts are 10mm x 1.25 and 100 long, 4 of them.
    The studs I'll put loctite on the threads going into the head. slide the manifold over the studs, and use the nuts with lock washers.
    This cost me $17. Hit ACE or a hardware store with a good metric selection. Took 30 minutes to scrounge all the parts, but it was not even tough. Much better price than $60+.
    Make sure all the hardware is hardened and grade 8.
    Hope that helps.
  7. toy_boy
    toy_boy Addict
    California
    1979 Toyota 4x4
    Napa Auto Parts
    Part #600-1814
    Stud size M10-1.25x40.5mm
    Brass Oxide Class 10.9 steel studs
    Brass nuts for better rust resistance and added strength.
    Comes in a packet of 2. Paid around $4 and some change per pair.
    *Note: I know for a fact these will work with a pre-83' 20/22R. Not sure about motors beyond that. But if not, I'm sure Napa Auto will have the same quality bits for your specs.
  8. jetas
    I bought the stock studs/nuts from the JY for about 6 bills. $.50 a per bolt nut. But i got smart and left the nut on the stud so i got a 2fer:D
    Hit the JY and dnt ask questions. Just take sh!t and pay
