Head gasket
Discussion in 'Engine/Drivetrain' started by coconut, Oct 22, 2010.
  1. coconut
    coconut Newbie
    Killeen, Texas
    So I just pulled the head off and I was wondering if anyone can give some advice on cleaning the old gasket off the block...I turned in the head to a machine shop so it's just the block im dealing with....also if anyone has pictures to show me the oil passages that some folks say not to get anything into it......on the same note should I coat the walls of the cylinders with ATF when all is said and done? Please help
  2. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    just get a gasket scrapper and scrape the whole deck of the block without gouging it youll be fine.. unless its pitted.
  3. DROPT
    DROPT Addict
    Whales Vagina
    razor blades, scotch brite pads, and some carb cleaner and go to town.
  4. Nook
    Nook Addict
    oregon
    Just your basic gasket scrapers as mentioned above, a sanding block helps, keep debris out of anything you can, the oil return hole is the large round one at the passenger rear, clean all the head bolt holes including the small one at the front under the distributor gear, make sure no oil in them, a bottom tap is a good idea on the head bolt holes, makes for a better even torque when reinstalling the head. Vacuum or blow out the cylinders but don't oil them, the oil only helps to glaze the rings lessening the sealing.
  5. coconut
    coconut Newbie
    Killeen, Texas
    Thanks fir the support I will try these suggestions and see what the outcome is
