Has anyone done a detailed write up for a roll pan insrall
Discussion in 'Exterior/Body' started by 93_Toy_Mini, Jan 9, 2012.
  1. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Has anyone done a detailed write up for a roll pan install
    Ok, I searched, so before I get some stupid, rude comment. I did do some searching before ok. Anyway...
    Has anyone done a detailed rollpan install write up? I have some questions and it would help out to see someone's work that has already done it.
  2. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    54 views and no replies?
  3. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    I just cut out most of the old "roll pan/lice plate mount" and clamped it in place and welded.
  4. confused.rat
    confused.rat Enthusiast
    Springdale, Ar
    1993 Pickup Ext Cab.
    Yeah what he said. It's not that hard. Just use spot welds the entire seam. Then once you're done take a grinder and grind the welds flush. Throw on some bondo. Then primer. Then some paint if you can paint.
  5. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Im installing mine in a few weeks. Looking at it if you dont have a stock bumper is basically just cut away that back panel thats recessed in giving you the entire rear cut out. Fit up the rollpan to match the body lines on the sides (may take some bending or such) then tack weld it on. Im going to weld it from the backside as to not have to worry about grinding down my welds and seams. Then like confused said Im going to bondo the seams, etch primer and paint. I usually always take TONS of pics and post them in my build thread so If you dont tackle it by the time I get mine done I'll be able to provide you more info at the time. Dont be bummed 50 people looked and nobody replied cause in instances nobody knows how, or if they think its a dumb question they wont reply either.
  6. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    I didnt cut anything. I just welded mine straight over the top.. looks awesome and has held up for years.
    JERSEY likes this.
  7. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    Its pretty self explanitory... And Titan I dont see how you welded it over the existing piece, it wont sit flush that way.
  8. randy20r
    randy20r Member
    georgia
    1976 toyota pickup
    seam sealer after you grind and smear it flush then let it cure 24 hours
  9. V8_TITAN
    Tampa Fl
    89 std cab
    mine sits flush, so it must not have been a problem.
    JERSEY likes this.
  10. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Sweet! Great picture...
  11. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Weird yours was flush without cutting. I had to cut a little off the bottom sides to make flush
