Hand brake battery and oil light blinks
Discussion in 'Interior/Electronics' started by yota89, Jun 28, 2013.
  1. yota89
    yota89 Enthusiast
    guam
    89 single cab
    I'm having some issues with my battery, hand brake, and oil light that it either blinks or stays on sometime and it mostly blinks is that showing that my alternator is going out and not fully charging lmk thanks
  2. raylcc
    raylcc Addict
    Denver, CO
    Sounds like a charging issue. Are your headlights dim or blinking? Since it also only seems to be happening to the instrument cluster, have you tried checking the connections? sometimes they can get loose and cause havoc.
  3. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    the battery, brake, and oil light is toyota engineer lingo for the alternators bad but still outputting something. It's still putting out something that would turn off the battery light (meaning you woulnd't know anythings the matter) but something still isn't right. On my old Cressida with a 5m, it meant the PS and timing cover oil leaks had put enough oil into the alternator and it was time to clean it again. On our trucks, you could try it but I reckon you'd be better off just getting a new one.
  4. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Help again i was installing the a/c bracket and compressor unplugged the
    heat temp and plugged it back when i was finished i just noticed
    that my lights went back on it was shutting off before but its back on
    and it shuts off when im at high rpm around 2k i didnt touch anything else
    i just stuck to one side of the motor bcuz i was butting the bracket and compressor
    on i also tried unplugging the line that i touched and plugged it
    back but the lights are still on help thankss
  5. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Geez . I'd have done sold this truck or parted it out. Too many issues.
  6. yota89
    yota89 Enthusiast
    guam
    89 single cab
    And wat if my truck has issues I'm the one thats fixing them u should just keep ur mouth shut if u have nothing better to do then to tell me wat to do with my truck I'm just asking for help not no dumb remarks next time I post just keep scrolling!!!!!!!!!!!!!!
  7. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Will do.
