Gross polluter in CA
Discussion in 'Engine/Drivetrain' started by sirdeuce, Dec 24, 2021.
  1. sirdeuce
    sirdeuce Veteran
    '86 4Runner and '89 2WD
    So, my truck failed badly on the last smog check. Cat was dead, for one, and the HCs and CO was way high. I replaced the cat along with the rest of the exhaust and since the truck had sat a long time before I got it I decided to clean the injectors. Turns out the injectors in the truck were 208cc/min injectors. Stock flow is 185cc/min. 13% higher rate that stock. So I installed a set of stock injectors and the HCs and CO dropped drastically. In the idle and 2500rpm test the HCs are now in the single digits and the CO is 0.00%.
    Jim Thompson, jetas and Erwin Merida like this.
  2. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Good info for someone having the same problems.
  3. sirdeuce
    sirdeuce Veteran
    Found out these injectors are offered as an "upgrade" being a 4 hole injector instead of the stock 2 hole. Makes sense as the 4 hole design does have a finer mist, but the stock ECU just can't compensate for 13% more fuel. Newer, OBD2 ECUs can handle it, but not our older, dumber ECUs. Might be able to use them in my MR2 though.
