got my parts ordered finally
Discussion in 'Engine/Drivetrain' started by IndianScout, May 17, 2010.
  1. IndianScout
    IndianScout Enthusiast
    1986 Yoda Truck
    now to rebuild the front of the motor..
    not bad for $76 I think..
    22re,,
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    sweet deal! they go pretty easy. have you done one before? i have to tear mine BACK down today, so i can take photos if you need.
    note: if you every send an engine block out, make sure that the front oil channel plug gets reinstalled. it runs down that cast rib in the passenger side of the block. without it, no oil pressure. DOH!
  3. IndianScout
    1986 Yoda Truck
    ahh great tip thanks,,
    nope this is my first time..
  4. standardbyker88
    lynnwood, wa
    for just a basic timing chain and oil pump on a motor thats already been in use, you wont have to worry about those plugs. they'll be there. and switching the parts is pretty easy. are you doing a headgasket at the same time? you dont have to remove the head, but it makes it easier.
  5. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    make sure you take the bolt out that goes straight down in front of the cam gear on the timing cover...very bad if you break the casing/head there.
  6. standardbyker88
    lynnwood, wa
    YES! Do not forget that. With the valve cover off, there will be a little pool of oil in front of the cam gear. Inside that pool is a bolt with a 12mm head on it. If you take it out, you should be able to pop the front cover free. There are a few bolts that go from the oil pan into the cover down below as well. The water pump bolts come out, because a few go into the block. Same on the oil pump. And then its just a few bolts to remove the cover itself. Also, when you put the new chain on, have the keyway on the crank face straight up. Rotate the cam the same. then just put the gears on matching those points and its lined up. A good trick is to rotate the motor until the notch on the balancer lines up to about 10-12* on the timing mark tab from the oil pump. Then when you put the distributor back in, you get it set so that the rotor aims directly at the number 1 plug wire. That will have your timing very close, and it should start right up. You can make tweaks with a timing light after its running. Also, use a little gasket maker inside the "half moons" at the end of the head. Not on the top, just where it curves around the head. It will help prevent oil from seeping by.
  7. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    WHAT?! please tell me this trick! lol...i'm assuming you meant engine not head right?
  8. IndianScout
    1986 Yoda Truck
    already have the pan pulled to clean it out..
    I may end up doing the head gasket
  9. dillinja666
    its worth it doing the headgasget if you have the motor already pulled and the pan and timing cover off, its just a few more bolts. Ive done it with out taking the intake or exhaust manifolds off before. sneaky sneaky..lol. BTW are you in SUNSET san diego? i havnt seen ya around, that or i just dont recognize your online name.... im stumps.
  10. IndianScout
    1986 Yoda Truck
    this is going to be done in the truck like an inline..
    no cherry picker..
    I'm from Sunset Whittier, I started back way back.. 84ish..
  11. dillinja666
  12. IndianScout
    1986 Yoda Truck
    Bob knows me :p
  13. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    I need more info on the no oil pressure plug... please let me know.. maybe the culprit to my 3 spun bearings in a row.
  14. standardbyker88
    lynnwood, wa
    If you keep spinning bearings, its probably somebody not putting the main caps on properly. The plugs are there from the factory. The only reason to double check is if you sent the block out for machining and cleaning. They take them out to flush out the oil passages.
