Good or bad idea
Discussion in 'Off Topic' started by yota4life, Sep 14, 2010.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    So I was thinkin when I redo my bed instead of doing a sheetmetal bed floor I was thinkin of doing a glass one. I work in a glass plant an can get anything I want at a cheap price. So I was thinkin of doing a nice sized glass bed floor to see the suspension an maybe have it a little tinted an maybe have some LEDs shinning on the suspension. Let me know what you guys think
  2. DROPT
    DROPT Addict
    Whales Vagina
    Pros, would look badass, and very unique
    Cons, would be a bitch to keep clean, and if its not a trailer queen i would worry about it breaking if you drive it alot.
  3. Litneon
    Cocoa, FL
    94 xtra cab
    Yeah, copy that. It's hard enough to keep my frame clean and I can reach most of it through the bed.
    There would always be that one nasty water spot....:rolleyes:
  4. IronNam
    vibrations and long term wear.... if you can figure out how to do it.
    and how thick can you go?
    and then its gunna be bitchin heavy.
  5. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    It would be hard to keep clean but I could always but like that clear film on it so when I go to shows or somethin I could tear it off. Or a tilt bed :) I can also go to almost 6 millimeters thick. I was thinking of doing like a sandwich of rubber around it
  6. andysmiley17
    andysmiley17 Veteran
    Louisville, Ky
    82 Diesel
    it would definitely be badass, but maybe a plexiglas floor would be better?
  7. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    i think it would look sick. if you get the thick one then that heps from breaking as easy but is that much heavier. But if you go thin then its that much easier to break over a bump or something like that but lighter. so if you think you can keep it clean and not break then do it. Tilt bed would help alot and look bad ass. You know what forget everything i said and do it. I like the idea
  8. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    i donno, sounds super unsafe... one hard turn and your bed torq's a bit and broken glass at high speed.
    why not plexi glass?
  9. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Well the glass will be tempered which is heat treated so it can with stand alot I watched a video on YouTube of a guy throwing baseballs at a piece an it didn't break an I've personaly have it pieces at work with shovels and they wouldn't break. Why not plexi? Well I can get a descent sized pieces of tempered glass for around $15
  10. dillinja666
    ok, well i was just worried about the safty part. if you think its safe go for it.
  11. project_DragTruck_v2.0
    project_DragTruck_v2.0 Veteran
    instead of the whole bed floor, how about just some windows. You could have them etched (for some old skool flavor) with something that suits you, then light the edges with LEDs so the etching shows up, but you can see right through the rest.
    kinda like this
    I dunno, just a thought.
  12. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Ya I kno wat u mean man. But I'm still thinkin about it. And it wouldn't me huge maybe a few feet an have a sheetmetal yota emblem lay over it
  13. Dgerfan55
    lake elsinore CA
    94 pickup
    Id say your mind is set on doing it so do it. Good luck and take pics
  14. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Haha it is kinda but I'm still open to suggestions an if it doesn't work right I'll go plexiglass
  15. jockeyshiftjoe
    jockeyshiftjoe Member
    Chatsworth, Georgia
    81 hilux
    Hey Yota, sweet Idea. but if your not into the plexi glass idea, how about pourable clear resin? you could build your template/box to the size and shape you need.its super bendable,so it can flex under hard tension, you can drill through it to attach the rubber to it and to the bed and it wont fray,or bust. it pours crystal clear, and you decide the thickness. plus if you decide to do a tilt bed it'll be easy to clean, you'll have the strength of glass, the weight of plexi, and since you'll be pouring it, it'll mend to any shape or design you wish. Also just as a little extra you could drill tiny holes in the sides of it and hotglue in l.e.d.s. and with the flip of a switch the glass will illuminate and show off your suspension. Just throwing an idea at ya. Best Wishes. -Joe
  16. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Sounds pretty badass. I'll def look into tht
  17. CurtisZ
    CurtisZ Addict
    Lake Stevens, WA
    1978 Pickup Longbed
    Why not use a 'panel' style method...
    Have sheet metal (or something else) panels line the bed floor that are relatively easy to remove. Make glass panels and a special bag to store them in. When you get to a show, remove the sheet metal and lay down your glass. Flip a switch for the LEDs; enjoy!
