going to check out a 5 speed trans ....
Discussion in 'Engine/Drivetrain' started by dudevato, Dec 30, 2011.
  1. dudevato
    dudevato Member
    so. california
    '75 20r/4spd mini camper
    out of a '79 truck with a 20r. I've got a '75/20r with a 4 speed. Anyone know if this will 'drop right in' as far as
    #1: clutch disc splines
    #2: drive shaft splines
    #3: come through my floor in the correct location
    #4: hyd. slave cylinger location/hoodup
    #5: drive shaft length
    #6: piolet (sp) shaft dia.
    It's being offered as 'leaks a bit & a bit noisy, but works fine' I can get it for $50. I'm interested in seeing if I like the gearing as far as how it handles 55/65 mph. I'd guess it's ok for the flat, maybe only down hill. I'm thinking this might be a fun project to see if I want to spend the $ on getting it rebuilt or getting another good running trans.
    Any and all input accepted, 'the sooner the better. thanks
  2. Inertia
    Inertia Enthusiast
    my truck is a 74 with a 5 speed w55 i bought it like that,they elongated the floor where shifter was i cant recall if the tranny was shorter or longer but works fine
