geo metro brake master?
Discussion in 'Suspension/Chassis' started by NotAvailable, Feb 16, 2010.
  1. NotAvailable
    NotAvailable Addict
    hey guys was wondering if anyone had a thread or knew how the geo metro brake master fits ona a 1990 toyota pick up?..any help would be great..thanks!
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    wont bolt right on, but any master can be made to fit with a little work.
    i did notice a datsun 620 at the yards that had the tiniest booster ive ever seet. it was about 4" around. lol. dunno how much "power" that adds, but its something. lol.
  3. NotAvailable
    NotAvailable Addict
    thanks for the input bro..some other people i met say its a bolt on and some said its not...so im out to find the truth because i am in need of a smaller brake master and even booster if possible..thanks bro
  4. CajunTaco
    CajunTaco Enthusiast
    Louisiana
    92 Reg Cab
    I got a tiny booster one off an 83/84 yota. Bolted to my 92 master and pedal.
  5. sitnlow4life
    sitnlow4life Enthusiast
    Detroit
    92 Std Cab 2.4L
    metro booster will fit
    I have one on my 92
    dont use the metro master though it sucks real bad
    you need to make custom brackets to adapt your stock master to the metro booster
  6. NotAvailable
    NotAvailable Addict
    how come the geo metro master sucks?not much power?
    thx for all the help guys!
  7. sitnlow4life
    Detroit
    92 Std Cab 2.4L
    Yes
    It does not displace as much fluid as the stock master
    What size wheel are you running?
  8. NotAvailable
    NotAvailable Addict
    currently running 17s but have my 20s set on the side..i also have a complete 4piston wilwood slotted and drilled rotors and calipers that i plan on ordering...i hope this helps me out..i need the space..thanks bro for the help.
  9. Ea4bes
    Ea4bes Member
    so cal
    92 single cab
    yeah i need to do the same to my 92. so the 83-84 booster should work for a 3in body drop?
  10. low_toyota92
    low_toyota92 Enthusiast
    Nashville, N.C.
    92 ex cab
    i got a metro booster on mine..... It didnt bolt right up.. i just cut out that section of th fire wall and re built it.. mines bd on 20s and it works ok. but i sugest ordering one of th 7in booster from speedway thats th way ima re do mine.. but i havent had any trouble with th metro, just dont know how well it would work if you had to slam on brakes.
  11. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    if you are planning on running a 4 piston setup you are going to need to get a larger master. more pistons more fluid needed. thats why the geo master sux cause it doesnt move much fluid. good luck with the build, brakes suck to piece together.
