Filed under: Hybrid, Minivan/Van, Geneva Motor Show, Europe, Toyota 2012 Toyota Prius+ - Click above for high-res image gallery As the second size extension of the Toyota Prius family tree, the 2012 Prius+ adds a healthy dose of roominess to the well-known fuel-sipping hybrid equation, and it's making its world debut at the 2011 Geneva Motor Show. There's seating for seven occupants inside, but the multi-purpose vehicle shares a clear design language with Toyota's standard-bearing Prius. What's more, it manages a low 0.29 drag coefficient thanks to its extended roofline and carefully designed front fascia. Equally as notable is the battery. This is the first lithium-ion battery pack to be incorporated within a non-plug-in Toyota full hybrid. Toyota has found enough room underneath the center console between the driver and the front passenger to fit the battery, which helps maximize interior space for occupants and their cargo. As you would expect from a Prius, there are three drive modes: A zero-emission EV mode that relies on electric motor power alone, an ECO mode that maximizes efficiency and fuel economy and finally a somewhat ambitiously named POWER mode that is said to boost overall performance. Toyota is saying that the Prius+ will be on sale in Europe in the first half of 2012, but it's coming to the U.S. around the same time in the form of the Prius V, which we previously saw at the 2011 Detroit Auto Show. Check out the complete press release after the break and be sure to check out our high-res image gallery of live photos below. Gallery: Toyota Prius+ MPV: Geneva 2011 Photos copyright (C)2011 Jeremy Korzeniewski / AOLContinue reading Geneva 2011: Toyota Prius+ sips fuel with room for seven Geneva 2011: Toyota Prius+ sips fuel with room for seven originally appeared on Autoblog on Tue, 01 Mar 2011 06:02:00 EST. Please see our terms for use of feeds. Permalink | Email this | Comments Read More...
