Gauge cluster w/tach 84-88 4wd i think?
Discussion in 'Parts and Accessories' started by Barret S, Dec 22, 2010.
  1. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    ok, i have acquired a gauge cluster, i'm not really sure what model this came from, but i will give details the best i can remember or display.
    i THINK this came from a 87 Toyota ext cab, 4wd, turbo truck. The guy i got it from sold me parts from one, i assume this cluster came from it also.
    The speedo is cable driven, and here are pics of the cluster, make offer.
  2. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    Bump! Any interest?
  3. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup
    i would if i had the cash how much u looking for ????
  4. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    a lot less than it's worth, i will take any halfway decent offer plus shipping on your part.
  5. laynrocker84
    laynrocker84 Member
    marshall TX
    87 reg cab 2wd
  6. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    replied
  7. laynrocker84
    laynrocker84 Member
    marshall TX
    87 reg cab 2wd
    send me your paypal and i'll have money to you tonight
  8. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    [email protected] also before you get this cluster, are you sure the oil press is messed up on yours? could be bad wiring to it and nothing wrong with yours at all, then when you hook this one up, same problem.
  9. laynrocker84
    laynrocker84 Member
    marshall TX
    87 reg cab 2wd
    cluster didn't come with this truck. It was originally a non tack cluster. I bought the sending unit for a gauge and swapped it when I put the cluster in. The gauge sits in the middle. It stays in the same place, even if the truck is running or not. Im really not sure how to check the wiring. I just figured some one had put it in a non tack truck and didn't change the sending unit and messed it up.
  10. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    ok, well in my integra i have a autometer aftermarket oil pressure gauge, it works based on resistive load. 100 psi ~ 220 ohms, 0 psi ~ about 20 ohms. So i would imagine most oil press gauges work the same, i'm not sure about diagnosing a oem toyota cluster though. Anyways to the point, if you want it its more than yours, just saying i don't wanna have to take it back if its not your cluster that is messed up.
  11. laynrocker84
    laynrocker84 Member
    marshall TX
    87 reg cab 2wd
    I wont b trying to sale it back to you. I may relist it after I swap the gauge, but I would not expect you to take it back.
  12. laynrocker84
    laynrocker84 Member
    marshall TX
    87 reg cab 2wd
    money sent!
    Thanks
    Trey
  13. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    ok cool, i'm looking for a box right now to ship it in, i will ship it tomorrow or wednesday and pm you tracking number.
  14. laynrocker84
    laynrocker84 Member
    marshall TX
    87 reg cab 2wd
    ok, thanks
  15. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
  16. laynrocker84
    laynrocker84 Member
    marshall TX
    87 reg cab 2wd
    I received it today!
    Thanks
    Trey
  17. lifted85
    lifted85 Newbie
    hedgesville wv
    85 xcab
    How much shiped to 25427
  18. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    Seriously guy?
