Gas Tank Replacement
Discussion in 'Engine/Drivetrain' started by 71hans, Oct 21, 2011.
  1. 71hans
    71hans Member
    Nebraska
    71 Toyota Hilux
    I am curious if anyone has put a different gas tank on a 71 hilux. My tank is original and is only 10 gallons. This is something that I can live with but would like to have a bigger tank. If you have put a different tank on your hilux, what have you found to be a good fit? My other idea is to get a jerry can to mount in the truck bed, which I think would look sweet, but after some shopping around I found that they are pricey and most of them come only with plastic nozzles due to the new air restrictions on gas cans.
  2. Old Rob
    Old Rob Newbie
    Your most likely needing to find a shop that makes custom gas tanks. I doubt you will find anything that will bolt right in. Check with a local radiator shop too, they may have an idea for you.
