fuel pump leak
Discussion in 'Engine/Drivetrain' started by cmonster86, Apr 26, 2010.
  1. cmonster86
    cmonster86 Newbie
    i rolled my 84 xcab pickup about a year ago and i am just now fixing her back up. when i got the engine (22R) running right i noticed the fuel pump was spraying fuel out of the weep valve. i assumed it was shot so i put a new pump on. the new pump had the same problem. i asked around and found out i was missing a spacer that goes in in place of the gasket, but when i put it in it seems to be leaking a little worse. any ideas on what the problem might be? i am at the extent of my knowlege.
  2. slacker
    slacker Addict
    Penticton BC , Canada
    84-7m-GTE custom
    there is actually 2 gaskets and 1 spacer ..
    gasket / spacer/ gasket
  3. Nook
    Nook Addict
    oregon
    By not having the spacer in there on the new pump is it possible you over extended the leverage and ruptured the diaphram in the new pump? just a thought.
  4. 22R_All_Motor!
    22R_All_Motor! Addict
    Houstone
    84 pickup
    oh yeah.. that could be true, too! i suggest, getting a new pump+ both gaskets and the spacers....
  5. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    or get an electric pump and eliminate the mechanical one.
  6. chris_pete
    chris_pete Member
    Cincinnati ohio
    1986 toyota pickup
    mine was leaking oil from the motor since the gasket was bad and i replaced it and dont do what i did and tighten it to much i cracked the whole pumb housing and the spacer..... yea i wasnt thinking
  7. planemos
    planemos Toyotaholic
    British Columbia
    Yea those old fuel tank pipes are really brittle
  8. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    MY PRIDE MY JOY MY TOY!
    yup, i've got one for sale if you wanna buy it.
