fuel problem
Discussion in 'Engine/Drivetrain' started by krazedprof, Jun 5, 2009.
  1. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    well got the ignitor today and still wouldn't start so sprayed starting fluid in the throttle body and it ran for a few seconds what would make it not get fuel the fuel pump works but could the efi relay cause it not to get fuel cause the fuel pump won't work unless i hook it up direct hopefully someone knows whats wrong
  2. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    Check your wires going to your fuel pump and make sure you get power to it, a clogged fuel filter will cause the no fuel issue as well, yes a bad relay or fuse will cause no power.
  3. krazedprof
    krazedprof Addict
    iowa
    ok checked the wire going from the harness for the fuel pump and i have no power what could it be also my flashers work on driver side but not passenger also have no power to that wire huh im stumped:brickknock:
  4. Evolmotorsports
    SCV cali
    1987 RN50 Hilux
    Check all the fuses and relays, the easy way to check the fuses is with a test light, turn the ignition on and touch both ends it should light up and the relays if they are good they will click when you try to use what they operate this is the easiest way for the novice.
