Fuel cell.
Discussion in '1984-1988 Build-Up/Project Threads' started by Frank Nick, Oct 22, 2022.
  1. Frank Nick
    Frank Nick Member
    Hello y’all. I’m going to run a fuel cell in my 94 pickup. Can you tell me how y’all set yours up. I have the rci aluminum 10 gal. Tank. I was wondering what size fuel line to use. Cheap eBay braided line? Summit racing fuel line. Thank you
    Erwin Merida likes this.
  2. Pearce
    Pearce Addict
    Washington
    1973 hilux
    Something like your a/n line is a rubber hose. Not recommended for full length runs because the fuel will deteriorate it. If the line becomes a problem you're replacing more then you would mixing a/n and hard line. Stainless fuel line is really affordable when I did mine a few years ago. I will point out that stainless is nearly impossible to get a good flare without the right tools and techniques. Something like a harbor freight kit you'll be lucky to get a flare for even a hose clamp connection.
  3. jetas
    Best bet is to run a stock size hardline as far as possible. Currently i have the factory hardline feeding the carb and a run of rubber line for the return, (i was testing to see if this would help my issues) i will be replacing both both hardline in the future
    im using these between the fuel cell and hardline for my feed/return lines.
    https://www.summitracing.com/parts/EAR-759156ERL
  4. Frank Nick
    Frank Nick Member
    I have the 22re motor. The hardline is good all the way to the back of the cab. So all I need is probably four feet of fuel line from the back of the cab to the fuel cell. Does anybody have pics of their fuel cell setup?
