FS: Engine/trans/ecu/all extras
Discussion in 'Parts and Accessories' started by thundering02, Mar 24, 2010.
  1. thundering02
    thundering02 Addict
    Fenton 63026
    Soon to be removed from my truck is the 85 22re engine trans ecu harness and all associated accessories (everything in the engine bay minus the radiator basically)
    Just shy of 204,xxx Trans shifts fine ... clutch has less than 30k miles (2.5 years old) the alternator has right about 5k miles on it spark plugs less than 1k
    The main problem it turned main bearing. I can probably get it to start again, but I'm not trying right now.
    Requested donation to my engine swap funds of $200 (or best offer) I figure the core plus working trans and new alt should be worth around that.
    Please come take it from me.
  2. thundering02
    thundering02 Addict
    Fenton 63026
    28 views and zero comments?...It is OBO
  3. TOY|STORY808
    TOY|STORY808 Enthusiast
    WAIPAHU TO LAS VEGAS
    1985 TOYOTA PICK UP
    how much for the wiring harness
  4. duckyaz
    duckyaz Veteran
    Pinetop, AZ
    well, maybe nobody wants to buy a bad motor.....
  5. thundering02
    thundering02 Addict
    Fenton 63026
    Fair enough to the statement ... but I was hopeing somebody needed more than just one or two things... Like the wiring harness request above.
    Re wiring harness request: Offer?
  6. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Id buy it on the spot, if it wasnt like 2000 miles away. You hardly get a RE setup that cheap alone.
  7. thundering02
    thundering02 Addict
    Fenton 63026
    Houston is only 11 hours each way.... but this is what I was talking about.
  8. thundering02
    thundering02 Addict
    Fenton 63026
    If you want parts send me some offers.
  9. LittleTruckThatCould
    LittleTruckThatCould Newbie
    You referred me over here from my post. Your parts could be used for a EFI swap onto a carbureted vehicle... plus the gas tank.
  10. thundering02
    thundering02 Addict
    Fenton 63026
    Well sorry but I still need the gas tank. everything else is there
  11. IndianScout
    IndianScout Enthusiast
    1986 Yoda Truck
    I'd be interested in the tranny with everything if you wern't so far away
    I'm, in ND
  12. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    find a way to get it all to me and Ill make a fair offer.
  13. butterscotch baller
    butterscotch baller Member
    Draper, Utah
    1976 Hilux
    if your willing to ill payshipping plus 150. let me know.
  14. thundering02
    thundering02 Addict
    Fenton 63026
    Butterscotch I'm sorry didn't see the post ... you have a PM.
  15. thundering02
    thundering02 Addict
    Fenton 63026
    No responses from any of the above comments... will start tearing this engine apart very soon so I can have truck ready for the new engine set up. Old and worn out will go to the trash unless specifically requested.
