I replaced my frt bumper 84 with a 95 bumper,I sniped the wirers for the turn signals and attached them to the new lights but,they don't work so, I re-connected the old ones back up and now they don't work. my brake lites,head lites,high beams,and tail lites work.I'm going to look for my hazard/flasher relay to see if that could be it.i found one 10 amp fuse blown on the drivers side panel but,that didn't fix the problem.the pic with my hand is the original setup.
Which two wires did you connect? Were they the same color? Did you flip them and see if that worked? Did you flip the bulbs? Did you check all the fuses??
turn signals yes,I connected the same colors to each other and they work.I must of had a bad connection.although I had to use the stock housing with the wider 95 lenses.it's wierd one side would work with the new housing and wires but, when I hooked up the other side neither ones would work.now my hazards and stereo do not work.
I had a similar issue with mine when i put the 92 4runner bumper on. I had the connector to the light connected the wrong way. I doubt u can mess urs up from the look of the connector. Any way of flipping the bulb? Or check if the contacts for the bulbs are corroded. Im just giving u things to diagnose. They might help you track down the issues. I had a b!tch of a time figuring it out and it was so dam simple
I rechecked the fuses under the hood again and it was a 10amp fuse that was blown.I still can't get the 95 turn signal harness to work,I tried acouple more things so for now I'm going with what I have hooked up,it works.
yea, that was a fuse for the stereo,hazards. man,one little mis-connection in the system can cause a big headache. it helped me learn and that's always a good thing.
