I was wondering if anybody has dealt with this that has an extra cab with a two-piece driveshaft I installed 3 inch lowering blocks on the rear end but I could not get the axle to a line with the pins because the drive shaft section was too long for the angle change so I had to disconnect the drive shaft to get the axle bolted down to the leaf springs and then I attempted to put the drive shaft back on but it was too long so what I ended up doing was unbolting the center support and try to give a little play in it which I was able to bolt the drive shaft back together which is a temporary fix any of you guys had this issue or maybe it's just the me
