first dropped mini truck
Discussion in '1989-1995 Build-Up/Project Threads' started by islandboyjt20, Sep 21, 2009.
  1. islandboyjt20
    islandboyjt20 Newbie
    Waikane, HAWAII
    94 extra cab 2.2
    so iam new to the site and this is my first dropped truck...:D i hope you guys like it and tell me what you guys think i should do...This is my 92 extra cab...all stock...until i cranked torsions way down cut the front bumpstop brackets also remounted the shocks lower on the bottom A-arm so they wouldent bottom out...but i put a valve spring from a V-8 on the top of the shocks between the shock body (the bigger part of the shock)and the first washer that holds the bottom rubber bushing...it works like a coil over when its about 2 inchs from bottoming out...i also cut out a little bit of the inner fender because of my stock rims and tires would rub and they still do when turning...out in the rear i got 3 inch blocks pulled the middle leaf and flipped the bottom load spring...(it does make a diffrence to flip the load spring about an inch or two...)with all this being done the lowest point on the truck is 2 inches off the ground:D...maby some smaller tires...?:rolleyes: heres the pici would love to here what you guys think...:)
    this is with just uncranked torsions cut bumpstop brackets and shocks bottomed out...
    this is with remounted shocks (mounted them about 2inchs down) and 3inch blocks in the back and pulled middle leaf and fliped load spring...
    what do you guys think...i want bags but i dont wanna miss out on all the fun in the static drop phase...:D
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    My 78 has 4-1/2" blocks and a yanked middle leaf. And very cut coils with alot of fender hammering/rolling. I love it. I just put shorter tires and I hit road turtles changing lanes in a few spots.
    I say ditch the hub caps at the very least. But i totally love steelies. It looks real clean and basic though. I like it alot.
  3. IronNam
    are you riding on bumpstops in the rear?
  4. islandboyjt20
    Waikane, HAWAII
    94 extra cab 2.2
    thanks man i would go lower but i gotta make a c-notch to go lower...ill will do it when i get the time and maby pull the load spring and make a traction bar so i dont get any spring wrap...
    im a steelies lover too...just waiting to get tired of the caps first...haha
    thanks
  5. islandboyjt20
    Waikane, HAWAII
    94 extra cab 2.2
    na i took the bump stops out and i have about 1 1\2 inches of space between the axle and frame...it does bottom out on big bumps though...
  6. TSLUX
    TSLUX Member
    WAIPAHU
    90 xtra cab
    loooks nice! welcome.
    is that rust on the cab?
  7. TOY|STORY808
    TOY|STORY808 Enthusiast
    WAIPAHU TO LAS VEGAS
    1985 TOYOTA PICK UP
    i just love how HAWAII rolls so dump
    static dropped
    and rock the hubcaps all day everyday
  8. standardbyker88
    lynnwood, wa
    You guys would love my truck. I have about 3/4" rear compression travel til I hit. It needs a notch too. Find some old steelies from a ranger or old Toyota. Something simple. Maybe 80s dodge cop car steelies and caps. That'd be cool.
  9. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Wow, you guys ride low over there. There's no way I could do that here with our roads.
  10. chucklzslowV6
    chucklzslowV6 Newbie
    Virginia, NOrth Carolina
    1990 shortbed 2wd
    PROVE that post up some pics
  11. standardbyker88
    lynnwood, wa
    The lack of travel?
  12. IronNam
    lack of travel sucks!
    btw, your truck looks good with hubcaps..
    i ran without mine for a long time. then i put it back on, then some girl was like.... did you do something to you truck? HAHAHAHAA
  13. standardbyker88
    lynnwood, wa
    Hey cin, do people ask IF you lowered yours a little? When mine was that height I got it all the time. People couldn't tell. Do like this guy and make sure there isn't any doubt. :D
  14. islandboyjt20
    Waikane, HAWAII
    94 extra cab 2.2
    i love what iam reading thanks guys...so i want to make a C-notch but some one told me it matters what rims and tires i will be running...can you guys help me out in that...
    and im glad to see someone from my own state...
  15. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Welcome the site, truck is looking good & as for notches then yea wheels size does play part in that. If you planning to go bigger than 16's then I do a stepnotch & if not then a c-notch will work. Oh & if you want to be even lower then get some smaller tires on the those rims.
  16. islandboyjt20
    Waikane, HAWAII
    94 extra cab 2.2
    thanks SMC ya i think ill do a c-notch i wanna run the stock rims and eventualy i will do bags...
    so the rims are 15's i think...so what size c-notch should i make...?
    and smaller tires for shure...
  17. standardbyker88
    lynnwood, wa
    I would say make sure you have 2-3" of travel in the back for compression travel. If you are doing the notch, I'd suggest putting either plate or square tube on top the rail and run a flat plate against that around the notch. In steps, top, cut/notch, plate sides. It'll add more strength in a short side area. It's how I though about doing mine. Somebody here did it that way and it looks good. Either sd yota or smc. I forgot.
  18. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
  19. IronNam
    omfg that bed is also dentless near the wheel wells... sexxyyy
    mine has a few.... grr
  20. islandboyjt20
    Waikane, HAWAII
    94 extra cab 2.2
    well the truck is not rust free i gotta do some bodywork and the bed has a couple of dents...but that the least of my worries...and as for the notch i think ill go like an 8inch...ill make one and post some pic...i know how you guys like pic...and Thanks SMC for the link now i have something to look at when i build it...o and whats the smallest tire you can put on these stock steelies...?
