filler plates
Discussion in 'Exterior/Body' started by YotaGirl, Nov 17, 2008.
  1. YotaGirl
    YotaGirl Enthusiast
    El Paso, TX
    94 Yota
    been looking around, only filler plates i see are for tail lights and tailgate handles. i'm looking for some for the antenna, anyone seen those around?
  2. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    I filled my in with fiberglass, no big deal!
  3. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    i just use little pieces of scrap metal, put them under the hole and trace it, then i cut it out with tin snips and weld it in. i even made my tail fillers. might be because i'm cheap, or just because i can:D
  4. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    yeah fiberglass worked well for me....then bondo smoothhh
  5. Collins94
    Collins94 Addict
    communist virginia
    94 single cab hilux
    i dont think i would fiberglass mine i agree with burnzya its easier and cheaper to make your own and weld them in no since in buying sumthing you can make yourself
  6. framescr8pintoy
    framescr8pintoy Newbie
    LAS VEGAS
    91 single cab
    make it, you probably have a piece the right size laying around somewhere, hell make all the fillers. i did:D
  7. YotaGirl
    YotaGirl Enthusiast
    El Paso, TX
    94 Yota
    ya except i dont really have any scrap metal and that just takes more time, guess thats what i'll have to do, figured itd be easier to just buy em since i've seen them for other trucks. oh well, thanks anyway :)
  8. CajunTaco
    CajunTaco Enthusiast
    Louisiana
    92 Reg Cab
    You can buy small pieces of 20 ga steel at lowes and homedepot
  9. Collins94
    Collins94 Addict
    communist virginia
    94 single cab hilux
    well if your wanting to just fill the antenna hole you wouldn even have to use that i have used the sheet metal they use in hvac duct work which is easy to cut and trim and welded it in you just have to be really careful not to burn thru it when your welding
  10. V8_TITAN
    Tampa Fl
    89 std cab
    glassss ittttttt it takes 20 to 30 mins to do it right, and mine is holding up fine !! post some more pics of your truck ! and what you plan to do with it, I wanna see more teaser pics :)
  11. burnzya
    bodied 73 hilux
    weld it!!!!!!!!!!!! glass belongs on vettes and really cool custom interiors i wish i knew how to make:D , maybe the s-10 filler would be close to what the yota is.
  12. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Do it right , make a metal filler,weld it in ,finish it off with a good grade body filer(Ever Glass)!
    You will re grate it if you 1/2 ass it. :cool:
  13. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    Yea being such a small hole its really simple to fill. Another thing you can try is again cut a small filler plate to shape and size, then use some body panel epoxy. The stuff is SUPER strong and it eliminates the possibility of warping the steel when welding or burning through! Then all you gotta do is smooth it all out with a little bondo!
  14. Red1979SR5
    Red1979SR5 Enthusiast
    Chimacum, WA
    Glassing it is one way, but the "correct" longer lasting way is to cut out a metal patch and weld it in.
  15. trap
    trap Addict
    orange county ca
    92 pickup
    I can make insane custom interiors out of fiberglass... but metal and I don't get along so well.
    I did weld my own antenna and door handles though
  16. burnzya
    bodied 73 hilux
    i tried fiberglass.... once. it was honestly sticky to the touch for 2 weeks. i think i'm going to just do a steel dash.
  17. trap
    trap Addict
    orange county ca
    92 pickup
    if you really want to learn how to do fiberglass rent (and copy) or buy these dvds
    Select Products
    you have to learn some technique and what materials to use... a lot of "fiberglass dashes" have no fiberglass at all actually.
  18. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    Trap, that link is going no where for me...:confused:
    I'd like to do my interior, if you've done some, post up some pics!!!
  19. YotaGirl
    YotaGirl Enthusiast
    El Paso, TX
    94 Yota
    yep thats what i'm gonna do :cool:
    thanks everyone for your input!
