Fast crane ignition, fuel injected
Discussion in 'Maintenance/Repair' started by Justin Danger, Jan 23, 2017.
  1. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Hi toyotaers,
    I just got my Fast crane ignition kit from LC engineering, and have some questions for anyone who has experience with them. It makes sense to me for big black to go to ground, blue to go to 12v+ (for the 22re setup), and the black and orange to the new coil. Where i lose it is the bundle of wires that included the orange and black also has coming out of it white, red, and orange wires that have a female connector with only 2 terminals. from my understanding, the yellow and white wire should connect to these after a male connector, yet the only other double connector is also female and the male connectors provided are singles not doubles, and i cannot get two to connect at the same time. i know this all sounds a bit convoluted, but i am just wondering if i don't understand what is going on here or whether LC didn't send the right connector.
    thank you in advance for any help you can provide
  2. Justin Danger
    Bay Area Peninsula
    So here is the coil hooked up:
    This is the white/orange/red I'm wodering about on the right that has the double female connector:
    This is the only other double wire connector, but it is also a female:
  3. Justin Danger
    Bay Area Peninsula
    After reviewing the PDF that LC has on their website, it looks like they did indeed send the wrong connector. I have contacted them to send a replacement.
  4. Justin Danger
    Bay Area Peninsula
    got the right connector yesterday, and spent the morning hooking it up. I followed the diagram and instructions, yet am getting no spark! PLEASE HELP! what do i check for, where do i check it? i do have a volt meter
  5. Justin Danger
    Bay Area Peninsula
    the i6 box gives me one red blink when i turn the truck on, but does not blink again
  6. Justin Danger
    Bay Area Peninsula
    sorry for the stream of conscioisness throubleshooting posts, but i am getting roughly 12 volts going into the unit
  7. Justin Danger
    Bay Area Peninsula
    same voltage getting to the coil, but not having 6 foot arms, i don't know how to check in the start position for trigger signal
  8. Justin Danger
    Bay Area Peninsula
    well, found some long leads, and trigger signal seems fine. now I am really at a loss
  9. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
  10. Justin Danger
    Bay Area Peninsula
    haha, did, they told me to call FAST, after two FAST techs gave up, i contacted lce again, but the tech guy was in a meeting
  11. Justin Danger
    Bay Area Peninsula
    just hard when where my truck is doesn't get phone reception and it is my only ride
  12. Justin Danger
    Bay Area Peninsula
    well, problem solved! I ended up throwing LCE's diagrams and instruction in the fireplace, then used my haynes manual and FAST diagrams along with names such as Phillip for coil positive amd Henry for power from the ignition switch to make a schematic of my own. Fired up, then had to re-time it and set the idle. runs kinda smooth now.at leadt it is running, working out the rest ain't so bad.
    TRUCK ACTION likes this.
  13. Justin Danger
    Bay Area Peninsula
    Ended up driving 250 miles yesterday (didn't really want to put everything to that much of a test so fresh, but circumstances necessitated) and she drove like a dream. The most noticeable improvement was climbing hills, there was so much less struggle going up steep twisty roads. Now that it is in and working, it is time to bundle and route the wires to make it look all pretty!
    Orlando Muniz and TRUCK ACTION like this.
