Failed smog. Any tips or suggestions please?
Discussion in 'Maintenance/Repair' started by 94Yota_05CBR1K, May 8, 2010.
  1. 94Yota_05CBR1K
    94Yota_05CBR1K Veteran
    San Diego aka SD, Daygo. Cali
    94 YoTa Mini 2wd
    I live in California and I just bought a 94 Yota 2 wheel drive 22RE motor. It failed the emissions aspect of the smog test and I don't know why. Everything else passed. The mechanic recommended that I get a tune up; new wires, spark plugs, oil change, and an engine flush. However, this all has been done except for the engine flush. It's only been about 1500 miles since the tune up. The motor has about 200,000 miles. Here is where it failed;
    25 MPH HC (PPM) max-60 ave-22 meas-72 :mad:
    Therefore, I barely failed by 12. I don't know of anything that is causing the truck to fail. Any tips or suggestions?
  2. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Bump up your timing a bit... @ 25 mph roll your EGR should start to kick in as well as the timing advance... Throw a can of Seafoam in the tank too!
  3. 94Yota_05CBR1K
    94 YoTa Mini 2wd
    Why would I mess with the timing if it's perfect? what does that have to do with emissions? I heard putting anything in the tank would clean it but not good for the lines.
  4. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
    Just offering you a tip and a suggestion... :shrug:
  5. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Its running rich, so it could be a couple things.
    Injectors leaking, worn plugs/wires, O2 sensor, cat converter, tps, VAF,
    any number of things...
    Go run it on the freeway (normal driving), bring it home and pull a plug out of it without idleing it too long, and take a pic of it.
    edit-It could be burning oil too and failed because of that. 200Ks definatly worn it.
  6. 94Yota_05CBR1K
    94 YoTa Mini 2wd
    Thanks for everyones suggestions. I found someone that will do it for $90 :) I will still clean injectors, check sensors, use seafoam, and drive it for awhile before the test. More suggestions if anyone has any. Thanks.
  7. 94Yota_05CBR1K
    94 YoTa Mini 2wd
    Has anyone tried Seafoam?
  8. arTuReX
    arTuReX Member
    Temecula
    1990 Xtra Cab
    Actually my 87 did not pass and we touched the timing and it pass no problem!
  9. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Give the guy $200:)
