Exhaust manifold gasket
Discussion in 'Maintenance/Repair' started by josealex1636, Feb 21, 2012.
  1. josealex1636
    josealex1636 Veteran
    Ontario,CA
    83 Toyota Pickup
    I have an exhaust leak from the manifold because it was missing two bolts and it burned the gasket and my question was is it hard to replace the gasket?
  2. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    Nope. Just pull the bolts out and slap a new one on. You sure you have to repace it? Mine had same prob once apon a time and I just threw a bolt in and tightened her up and leak went away.
  3. josealex1636
    Ontario,CA
    83 Toyota Pickup
    Yeah bro because on the valve cover on the side by the cab der is lik black stuff i think carbon from the exhaust that is leaking from the top and plus ill just buy new bolts and new gasket
