Motor 22r Balenced bottom end Wisco 10:1 forged pistons Moly rings Large s/s valves, 3 angle bronze guides dual valve springs viton seals stage 1 cam port, blend and match ported intake by baker msd 6 msd blaster 2 msd wires e3 plugs k&n downey header chambered muffler 2.5 exhaust with flex high tuck crawler fly wheel 4speed Big 8" rear diff rebuilt w/390 gears and detroit ez locker suspension front tubular control arms Chassis tec spindles billet cross shafts poly bushings strut frame alco 1" swaybar heimed streering idler gusset sway a way torsin bars kyb gas adjust shocks rear blocks alco 3/4" sway bar (not installed) kyb ga adjust shocks cross drilled rotrs, ceramic pads, all s/s braided lines Weld Super single wheels, Falken Zeix 502/ 205/50/15 4x4 bed and front fenders, roll on bedliner, carbon fiber hood, clear corners, and tails MR2 Turbo buckets, grant formula wheel, keyless entry, alarm, good tunes, mp3 amp 8" sub And I'm sure lots more that I haven't listed. passes smog great, even with a built motor, put 175 to the wheels without smog eq. and sidedrafts with 33'tires. This is a bitchin little truck and has gobs of torq, drifts great, but needs a little work to be perfect, drive shaft has a vibration and is limited to street use because it has a 4 speed, if you install a 5 speed all would be great, and the body needs some work, I am selling it because I am stuck on work comp waiting for surgury and need to pay bills otherwise I wouldn't ever sell it. <a href="http://s196.photobucket.com/albums/aa272/blsftw/?action=view¤t=SANY0971.jpg" target="_blank"><img src="http://i196.photobucket.com/albums/aa272/blsftw/SANY0971.jpg" border="0" alt="Photobucket"></a> <a href="http://s196.photobucket.com/albums/aa272/blsftw/?action=view¤t=P1010033.jpg" target="_blank"><img src="http://i196.photobucket.com/albums/aa272/blsftw/P1010033.jpg" border="0" alt="Photobucket"></a> <a href="http://s196.photobucket.com/albums/aa272/blsftw/?action=view¤t=SANY0984.jpg" target="_blank"><img src="http://i196.photobucket.com/albums/aa272/blsftw/SANY0984.jpg" border="0" alt="Photobucket"></a> <a href="http://s196.photobucket.com/albums/aa272/blsftw/?action=view¤t=SANY0985.jpg" target="_blank"><img src="http://i196.photobucket.com/albums/aa272/blsftw/SANY0985.jpg" border="0" alt="Photobucket"></a> <a href="http://s196.photobucket.com/albums/aa272/blsftw/?action=view¤t=SANY1056.jpg" target="_blank"><img src="http://i196.photobucket.com/albums/aa272/blsftw/SANY1056.jpg" border="0" alt="Photobucket"></a> $3500 OBO Contact only by email [email protected] I live in SCV. Ca.
Sorry about the injury and having to sell the truck. I just bout my 87 a couple of weeks ago so I am not in the market, but I do live down around Monterey and would like to pick your brain on things truck related.
Thanks Guys, Trap I pretty much made it myself, 4130 cromo tubes, threded rh and lh, heims are from speedway, misalignment spacers are from ballistic fab, bolts are OSH, and i drilled the spindles and center link, I did notice less slop and a quicker more touchy wheel.
Ok Im throwing in the towel and Im done $2500. and its yours, and it comes with a 5speed not installed. I cant work on it and I'm going nuts and I'm sick of listening to my wife bitch about it.
Looks like you have a Downey lift kit in it and you lowered it with spindles. Those tubular arms look like Downey ones as well as the cross shaft and the idler brace. Neat idea! James
dang. my girlfirend is looking for a vehicle and this would be perfect. If she can get the money in time then you'll be hearing from me.
Yeah it is a downey kit, but it is a early kit when they didn't compensate the bj plate for correct geometry for cranked torsins at ride height. The tubular arms , heimed streering, saw torsins, 1"swaybar and strut frame make a insanely ridged suspension, the billet crossshafts, idler gusset make it stronger.
Send me more pics. Im highly interested and would like some more info. Send me a email [email protected] with more pics of the inside under the hood under the truck and where the hell is SCV? Also i'd like to talk more about it over the phone. give me your number and ill give you a buzz
