ever broken tire beads off the rim ???
Discussion in 'Off Topic' started by V8_TITAN, Jan 21, 2009.
  1. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    and need a quick fix when your out in the woods ? im going to try this one day lol
    SORRYY I DUNNOO WHY THIS WONT WORK !!! ILL FIGURE IT OUT SOON OR SOMEONE ELSE WILL ?!?
    try this
    http://vids.myspace.com/index.cfm?fuseaction=vids.individual&videoid=50764593
    <a href="http://vids.myspace.com/index.cfm?fuseaction=vids.individual&videoid=50764593">Tire Trick</a><br/><object width="425px" height="360px" ><param name="allowFullScreen" value="true"/><param name="wmode" value="transparent"/><param name="movie" value="http://mediaservices.myspace.com/services/media/embed.aspx/m=50764593,t=1,mt=video,searchID=,primarycolor=,secondarycolor="/><embed src="http://mediaservices.myspace.com/services/media/embed.aspx/m=50764593,t=1,mt=video,searchID=,primarycolor=,secondarycolor=" width="425" height="360" allowFullScreen="true" type="application/x-shockwave-flash" wmode="transparent"/></object>
  2. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    Hahaha yea ive seen that done before. You should see it when they fill up a Tractor tire with ether and lite it up! BANG!!
  3. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    i've done it on tractor(semi) tires, but have always been told to not do it on small tires.
  4. TSA15
    TSA15 Member
    That does work. It's not a good idea... But, it does work. Take it from a tire guy. We have marks on the 20' ceiling at work where tire/rim combos have popped off the mounting machines and hit the ceiling. I also know a guy who got blown clear out of the bay door because one blew off the machine knocked him out the door. Most large 6-ply tires take between 40-50 psi to seat the bead. Stiff 10-plys (think super swamper 38's) can take up to 100 psi. That's close to 50 inches of surface area at 100 psi. That's 5000 pounds of force coming at you if the bead pops hard enough to push the tire over the rim of the wheel. And believe me, it does happen. If you are going to do serious rock crawling or four-wheeling, just buy a real set of bead locking wheels with matching tires. That way the only risk of dying is from rolling the truck off a cliff. That's the way you want to die if you are out rock crawling. Not having your head taken off by a renegade tire...
  5. burnzya
    bodied 73 hilux
    ^ true, my dad used to do tires and his friend was killed when a tire came apart while filling it. he didn't have it in the cage.
  6. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    Yea its scary stuff. I live out in the country area and there are alot of farmers around. The tire shop i did co-op at back in my highschool days used to use ether on the calcium filled tractor tires. That was crazy stuff. I will never do it that way.
  7. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Ive seen it done on tractor & semi tires as well too...its one crazy ass site!
