We just recently did a automatic convention to manual transmission swap everything seems to look good but the motor doesn't want to turn. Started and gages doesn't turn the fly well and we try turning the motor from the front pulley from a 19 deep and it seems like the motors frozen. The truck was just running yesterday.
Did you have somebody holding the clutch in while you tried to turn it? If not, you probably just didn't get the switch that only lets the engine start when the tranny's in park or neutral jumped.
How'd the swap go?!?!?! Omfg i wanna convert mine so badly... i need a list of all the manual parts..
it went fine after we found the problem........... well we got a deal we got a 5 speed trans, the pedal assembly(clutch and brake pedals), clutch sleeve, clutch lines and master cylinder, shifter, clutch, and flywheel all for 300 bucks cheeee...............and youl hafto buy a new pilot bearing its goes for 20 bucks at napa..............then get to wrenching haha
