Engine Trouble!!!
Discussion in 'Engine/Drivetrain' started by PapaBear1013, Jan 14, 2009.
  1. PapaBear1013
    PapaBear1013 Addict
    Lancaster, Cali
    1994 Std Cab
    OK, so I was crusin along today when my yota started acting up. :confused:As soon as I hit bout 70mph the truck started to misfire. I noticed it only happens around the same speed. It accelerates fine til I hit the high rpm's. I recently have changed spark plugs, wires, cap & rotor, 02 sensor....im thinking it might be my fuel filter or maybe bad/dirty injectors. I recently used Redline fuel system cleaner also...How hard is it to replace a fuel filter? Has this happend to anyone? Its really annoying! :mad:
    1994 22re FI
  2. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    it souldnt be hard at all to replace teh fuel filter...
  3. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Sounds alittle like what happened to me a few months ago...I had to chabge the fuel filter that was near the gas tank & the one thats on the passenger side of the block as well. If it was a bad injector then it would run like crap even at idle so Im thinking you ok there! Oh & on a side note...the fuel filter on the block is bitch to change lol!! :)
  4. cmcpher
    cmcpher Enthusiast
    Raleigh(ish), NC
    93 Std Cab 2wd
    I'll throw a couple of areas to look at....changing the fuel filter wouldn't hurt if you haven't done so at all. There is a lot of trash these days in the fuel supply.
    A few things you could check:
    • Check the fuel injector connections for shorts, could just be a dirty connection..nothing electronic cleaner can't fix.
    • Check the EGR system
    • Check Throttle Positioning Sensor
    • Have you checked your timing?
    • A dirty injector, as you stated?
    I know you said you changed out quite a few things...never hurts to look over the things you recently changed to make sure there are no vacuum leaks...or wires grounding out.
  5. PapaBear1013
    PapaBear1013 Addict
    Lancaster, Cali
    1994 Std Cab
    Well looks like a got a few things to rule out. I'm definately gonna replace the fuel filters beacause I dont think the original owner ever did. It's just frustrating because my 22re is newly rebuilt! I really appreciate all of your replies. Ill let you know how it goes. Thanks again :waytogo:
  6. PapaBear1013
    PapaBear1013 Addict
    Lancaster, Cali
    1994 Std Cab
    SMCTOY thanks for giving me the heads up...Ill let ya know how much fun I had replacing the fuel filter!
  7. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    What about your fuel pressure regulator?? They can give similar issues when they start to act up. Just a thought. Id go there next if the fuel filter doesn't solve it.
  8. PapaBear1013
    PapaBear1013 Addict
    Lancaster, Cali
    1994 Std Cab
    Thanx Sound...Ill check it out also!
