Engine swap ideas, long term project
Discussion in '1989-1995 Build-Up/Project Threads' started by Hasno1342, Mar 7, 2021.
Tags:
  1. Hasno1342
    Hasno1342 Newbie
    Looking in to doing a long term project with my 94 2wd pickup, i have wanted to do a 2jz swap for about 2 years. Any one here done it? I know ill need a new trans (i think the R154). What else would i need?
  2. jetas
    Engine, Trans, wiring, fuel system, mounts etc... will be needed. Lots of odds and ends
    The swap has been done many times. There are a few here just not sure about anyone documenting it here. Google will be your best friend
    Hasno1342 likes this.
  3. Hasno1342
    Hasno1342 Newbie
    The differential is where i get lost, i knew about the motor, the mounts, and the trans. I havent seen anything in wiring or fuel system
  4. jetas
    Diff should be ok. Id worry about getting it running then change the diff is if it needs it.
    of and you may need a new driveshaft
  5. Liquidhandwash
    Liquidhandwash Enthusiast
    Northen VIC
    1980 diesel
    One of the nicest conversions I've seen is a 1gg engine into a Hilux. They are a very small light inline 6 with 180hp standard. They are fitted to Toyota Altezza/Lexus IS 200 Because they are so small there is no need to cut into the firewall or radiator panel.
  6. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    I want to build a windsor 5.8 for the 5th gen. NWOR has solid mount kits for that and many company's offer adapter plates for your gearbox of choice. Sky really is the limit!
  7. Erwin Merida
    A cammed and cross ram itb'd 2nd gen 1uz also..cherry!!
