Engine Swap - 350 vs 355
Discussion in 'Engine/Drivetrain' started by Bassface194, Sep 17, 2011.
  1. Bassface194
    Bassface194 Newbie
    So Cal
    1972 1/2 Hilux
    Wanna swap a v8 into early 70s hilux but dont know which motor would work best n fit easiest. any ideas? ford 302 vs 350 small block vs 355 short block? i dont know, any suggestions wud be great thanks
  2. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Ford. Narrower is better in an early truck.
  3. 90ls1toy
    90ls1toy Member
    AUGUSTA GA
    90 EXTRACAB SR5
    Both will work fine. There is no physical outter difference between a 350 and a 355 only the bore size.
  4. Bassface194
    Bassface194 Newbie
    So Cal
    1972 1/2 Hilux
    What kinda 302/ 5.0L do you think I should use? I'd love to use a fuel-injected late 80's-early 90's Mustang 5.0, they're relatively cheap, easy to find, and a big aftermarket for 'em; but that could get complicated with all the engine computers and what not
  5. Raffaelli
    Houston
    82 Longbed 2WD
    Im not kidding you. It takes 3 wires to make a 5.0 harness power up. One keyed power, one ground and one to battery power.
    Give it fuel pressure and it'll run.
    A mass air, 5 speed, 5 liter v8 in stock trim makes right around 200 to the wheels. 260+ tq.
    Drop that into any 2400lb truck and it'll roll faster than you'd want to go.
    If I was you, look for a 96-97 explorer in the junkyards. Buy the whole motor for 150 bucks and rebuild it for 3-400. Then track down the mustang dizzy, harness, computer, sensors (ect...), and a transmission. A decent cam, and itll push out 240 easy.
  6. Bassface194
    Bassface194 Newbie
    So Cal
    1972 1/2 Hilux
    hmm i see, that actually sounds pretty realistic n low budget. I bet i could get er up to 270 ish with headers, race exh, n cold air intake. would i have to reinforce subframe or anything? sounds like im asking for trouble almost tripling the power of a 40 yr old truck only built for 100hp
  7. Raffaelli
    Houston
    82 Longbed 2WD
    The axle, and frame will handle the power fine.
    Youll need to get creative with your brake setup though. I run 95 LS400 calipers and rotors on my truck. Brings it down from triple digit speeds really quick. :waytogo:
    Anythings possible. :thinking:
  8. Old Rob
    Old Rob Newbie
    V8 swap
    You can use either the Ford SB, Chevy SB V8/6 with no serious issues. The stock frame and suspension will be more than sufficent up to about 600HP. Note that the Ford is approx 1/2" wider, 1" longer and almost an inch taller than the SB Chevy V8/6. The Ford will be about 30 lbs lighter. Both will require some form of header. Bolt in engine adapters are avail for the Chevys 72 up.
    Ford swap will require some rework of the front xmember or use a rear sump mustang pan. You may need to do a little drop of the center link to clear the oil pan. For the best results you will want to put the engine crankshaft centerline the same as the stock Toyota. This includes the trans output shaft. Both can use an aluminum radiator with minimum of trimming needed of the rad core support.
    FYI I've done numerous engine swaps including minitrucks.
    You can get some ideas at Pictures by OldRob - Photobucket
  9. rudedog
    rudedog Newbie
    n cali
    1971 hilux racer
    Hey so did u find out what your going to put in that truck?
  10. vancetater
    vancetater Enthusiast
    santa cruz ,ca
    74 hilux shortbed
    ford 302 engine is shorter in front to back length so less firewall will need to be cut also radiator/fan clearence is good but fords are more expansive to build. a SBC is way cheeper and alot more aftermarket parts are availabe cheep and very much better built than a POS ford product dont put ford anything in your vehicle it will degrade the value :Djust my opinion
  11. Inertia
    Inertia Enthusiast
    ford and chevy suck yoda baby
