Engine sputters after shut off
Discussion in 'Engine/Drivetrain' started by paani_boy, Jan 25, 2013.
  1. paani_boy
    paani_boy Newbie
    Hawaiʻi
    87 single cab
    After I welded up some exhaust leaks, my 22r (32/36webber, cheapo headers) still sputters a few times after i shut it off. Sometimes it squeals at the end, sounds like gasses coming out the top end of the engine instead of the exhaust.
    Any suggestions on how to fix that? stock 22r, 32/36 webber, cat delete, flowmaster 50, pacesetter headers.
    Never had the problem when I had the exhaust leak. It was a pretty big one, less than a foot after the header.
  2. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    maybe running to rich? idlejet/screws to far open? there's always google. thats how i fixed my bad idle problem.
  3. Kenstyles
    Kenstyles Member
    Bay Area, CA
    76' sr5, 95' std. cab
    Idle stop solenoid? My car used to sputter after I turned it off and after I changed the o rings on the solenoid it got rid of it.
  4. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Sounds to me like it's just dieseling.. Mine does it when the idle rpm is too high like when I stop and quickly shut it off or when my idle was just set too high.
  5. NotAvailable
    NotAvailable Addict
    Check for vacuum leaks on the carbs adapter plate etc. Had same problem.
  6. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    mine did it twice before I rebuilt the carb. when I took it in, the guy said it had a ripped diaphragm.
  7. paani_boy
    paani_boy Newbie
    Hawaiʻi
    87 single cab
    my carb is manual choke. I'll try letting the rpm settle down a little before shutting it off. See if that helps.
    I'll try messing around with the carb, get it to run a little leaner. Any other symptoms of a rich running carb??
  8. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Check your timing over advanced timing can diesel a motor when the carb is running rich or if u have a fairly high idle a lot of webers have weak throttle return springs I use a stiff one on mine to help close my throttle quicker
    Symptoms of rich carb black plugs smelly exhaust black smoke poor gas mileage sluggish mid range performance hard starts when hot .. Might wanna check/adjust float level or mess around with a few different jet sizes of you can't lean it out with the adjustment screw
  9. harold.p.flores
    harold.p.flores Member
    Residing in Copperas Cove Tx.
    1988 toy
    I had the same issue with my weber 38, and when I went back through my Weber 38 installation I figured out the my fuel pressure was too high with the stock fuel pump so I added a fuel presure regulater and set it to the proper fuel pressure wich you would find on your installation manual for your weber if you can't find it call the weber tech support line and they will help you find it. When I added the fuel pressure regulator it worked just fine.
  10. lowplz
    lowplz Member
    Hayward, CA
    87 longbed
    timing?
  11. first80toyota
    Pacific Northwest
    '77 Hilux
    If its running rich you should smell it and probably see some black smoke.. Are you running a fuel regulator with your weber?
