Engine Runs BACKWARDS --> Help!
Discussion in 'Engine/Drivetrain' started by Lostandconfused, Jun 28, 2011.
  1. Lostandconfused
    Lostandconfused Member
    Yep, it's true.
    The engine on my 1974 SR5 is turning backwards.
    No, it does not run.
    But the distributor is suppose to turn counter-clockwise.
    Instead it turns clockwise.
    Any ideas?:runaway::eek::eyecrazy:
    ( ANd yes, I know there is a wiring issue. I'm just not sure where to look. Hence this post. )
  2. Enemy of the State
    Enemy of the State Enthusiast
    1985 xtra cab
    The only thing I can think of is the starer.
  3. Lostandconfused
    Yep, it is probably the starter...
    But I've gone to a variety of part stores and even a starter shop.
    All say it is impossible for a starter to turn backwards.
    In other words, the bendix (sp??) can only go one-way.
    Yet it has to be the starter.
    It's wired wrong and makes everything go in reverse.
    I'm told that this is impossinble.
    But it is happening!
    ( Will post video when it stops raining locally.)
    Anyway, I've pulled the started and had it bench-tested.
    It runs fine in the test.
    So I'm still lost...
    Any help?
    I don't want to trash a '74!
  4. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Stater
    Try wiring it in your truck but dont bolt it in and see what its doing. The bendex only pops out in one direction.
  5. Nook
    Nook Addict
    oregon
    18R engine, firing order 1-3-4-2
    distributor rotation-"clockwise"
    point gap-.016-.020 in.
    timing-7' BTDC
  6. Lostandconfused
    Nook --
    Thanks for the specs.
    Problem: this is a 20R engine.
    This is the first year of 20R engines.
    I have a 1973 Hilux, so these specs will go to good use.
    I still have no idea why the engine turns BACKWARDS.
    The carb actually "burbs" exhaust.
    And the negative ground from the engine to the back firewall is hot.
    So yes, it's wiring.
    But which wires???
    And why is the starter still turning if it is wired incorrectly?
    :brickknock:
  7. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Maybe your battery is hooked up backards??? Idk, that is some weird sh*t! :lol:
    Is the crank pulley turning clockwise? Sometimes the carbs burbs if the timing is off too.... Good luck! :waytogo:
  8. Nook
    Nook Addict
    oregon
    You must have a real late model 74 truck, as 75 was the first year for the 20R in the pickup according to Toyota
    Something just doesn't make sense here, distributor rotation on the 20R is also clockwise, you tested starter and its fine, battery is connected correctly? negative to ground, positive to starter? turn the engine over which way does the crankshaft pulley turn, should be clockwise also.
    If it had a direct ground somewhere like in the alternator sending voltage to ground, then either fuses/ fuse links, would be blown, wires melted, something, it just wouldn't flow voltage everywhere like through the engine block to the head ground, at least not for long.
  9. jetas
    take it out of reverse....
  10. Malessohomegrown
    Malesso,Guam
    Are you from Australia or something. Doesnt sh*t spin the other way over there. Just kidding man I'm lost already.
  11. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    wait...your distributor is turning clockwise....thats normal.
    sounds like your timing is really off. Also make sure the ground at the back of the head isnt the only one for the whole car and that everything including the starter isnt grounding through that tiny wire.
