Electric Fan settings
Discussion in 'Engine/Drivetrain' started by SD YOTA, Jun 27, 2009.
  1. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    who here is running electric fans? i am planning to run a 180* thermostat with dual 10" fans.
    how do you have your fans setup? what temp do you have them come on? i will have 2 10" fans so would i be good to set one to come on as a primary and use the second one as a aux. or should i have both come on at the same time? let me know what you guys have....:waytogo:
  2. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    I used to have a flex a lite black magic in mine..it had an adjustable knob on the fan which made it nice to adjust..I believe i had mine around the same temp but I never knew the exact temp because of it being adjustable..
    are you building a fan set up from another car or buying a kit?
  3. SD YOTA
    i am buying/building a kit. i can get the fans at work for 28 bucks (special deal :D) and i found an adjustable controller kit for setting it up.
  4. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I run a Spal 16" electric fan & use a Centech fan controller,set to what temp you want on,with over ride switch( instant on):cool:
