egr vaccuum and spark plug gap size
Discussion in 'Engine/Drivetrain' started by l0wlux, Jan 28, 2009.
  1. l0wlux
    l0wlux Member
    hey was wondering on what the spark plug gap is for my truck and where my egr vaccuuum is on my truck and how to block it
  2. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    which motor do u have?? also here is a link for the general block off plates. they are pretty easy to install also. but if u have emission checks do not do this as u take it off..
    exhuast--
    http://www.toyotacatalog.net/M1WebG...UniqueID=35ABA509-F177-4E45-8358-4A96754350B5
    intake side--
    http://www.toyotacatalog.net/M1WebG...UniqueID=A892DE49-4C26-45C6-9A84-D715971CF42D
  3. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    I believe the sparkplug gad should be printed on a white sticker on the under side of the hood. Or somewhere under the hood.
  4. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    gap size is .032 btw.
  5. l0wlux
    l0wlux Member
    i have a 87 22r m0t0r whats the spark plug gap f0r that? als0 i herd fr0m my friend that i g0ttah take 0ut the wh0le egr valve and vaccum thingy is that true?
  6. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    to answer first question....
    to answer 2nd question - depends, u DONT have to remove the egr system, i did because it was clogged and it doesnt really do that much, that and i put on an aftermarket carb, just made things easier.. but if u do take out the egr valve, yes u need to remove everything that goes with it.. if u need a pic i can see what i can find later..
  7. l0wlux
    l0wlux Member
    pic please and is it hard t0 take everything 0ut that deals witht he egr.
  8. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    IMO no it doesnt, took me a little bit only becuase it was the first time doing it. i will try and get ur pics this weekend for you. I will also probly attempt to do a write up on how to remove the egr system.(but it will be awhile before that happens)
    Any1 have pics of a stock 22R motor? if so that will help :)
  9. l0wlux
    l0wlux Member
    aye thanks ahh this foeums gives the load of help
  10. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    We aim to please!! :waytogo:
  11. l0wlux
    l0wlux Member
    hey frinzo omost finish with the pics and write for the egr?
  12. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    unfortanly not :( i just ordered the egr block plates. they should be here in a week, from there i cant say how long it will take me to get it done as im tryin to get the truck back on the road. im tryin to see if i have a stock 22r pic, as my 22rte doesnt have the same egr system...once i find that i can atleast give u a better idea what it is..
  13. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    hey lowlux, anyway i can get u to take pics of ur engine how it sits now? i will need stock pics, when i was doing my first truck i didnt take pics :( if not not a prob, i will probly be able to find a truck around my area..
  14. l0wlux
    l0wlux Member
    you want me to take pics of my engine and send them to you is that what your saying? and what do you need a truck around your area for?? also can i just cut of the pipes of the egr and fing a welder to weld the pukas on the flanges????? and what do you mean how my engine sits?
  15. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    Yes (but take the air filter off)
    I meant, i can find a stock truck around my area. i see these trucks every where..
    i wouldnt do that..its easy to make the block off plates if anything. BTW what is pukas?
    Sorry, that is my way of talking (slang)
    The only pics i have of my truck(s) is when the engine was modded.
  16. l0wlux
    l0wlux Member
    ok i will take pics of my truck tomorrowand get them to you.
    why do you need a stock truck??
    pukas or puka means holes in hawaiian......
    and hw do i make or how did you make egr block off plates???
  17. doorslammer
    doorslammer Member
    Western Australia
    95 trayback
    ive got a photo of a stock motor but its probably not very helpful
  18. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    cool, doorslammer, never seen a pic of a right hand drive engine bay...
    L0wlux, the reason i need a stock truck is so i can show in the write up how it looks stock, then once u get the plates on. a Before and after pics. I just bought the block off plates from lcengineering. but if u know someone good with cutting metal just trace the pattern from the egr valve...i will post up the after pics to give u an idea...
  19. l0wlux
    l0wlux Member
    frinzo got the steps to cutting the metal ready if not take ur time
  20. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    its pretty easy. i will post up tonight of what mine look like, will give u an idea on what to do. but when u take the pipe off the exhuast manifold, ur going to need to take the egr valve off too..but i will post what i have tonight, i had some stuff come up last night on me..
