Wanted to share this with my fellow mini truckers just purchased from airbagit.com bolt on front brackets
Most items from that site are not so good,beware!! There is a lot of force with a air bag,that is why the brackets are always welded & must be braced!! I've seen a lot of bad installs & a lot of bent / failed brackets, front & rear!! If you insist on using them make sure you use grade 8 bolts !! And this why I always tell everyone do your research!!!
http://www.airbagit.com/mobile/Product.aspx?ProductCode=BRACKETTO8495F Itll probably be welded along with bolted depending on how i feel about it, another member here is also running them thomas johnson he has it welded and i bolted i thinj but hes running drop control arms with them
