Easiest way to remove front shocks and springs?
Discussion in 'Suspension/Chassis' started by Bottle, Dec 3, 2017.
  1. Bottle
    Bottle Member
    Hey guys, I got my truck on stands right now, finally got around to soaking on some suspension parts I had that I've been lazy about. I removed the nut on my upper ball joint and death as, but can't seem to get it to drop the lower arm and spindle. Is there something else I need to remove? Trying to avoid unfolding anything unnecisary as there is 43 years worth of crap on this thing and I have to scrub down every nut before removing
  2. jetas
    Support the LCA with a jack. Hit the spindle with a hammer where the BJ goes thru the spindle. Its should seperate.
    BJ comes up and off the control arm after removing the 4 nuts and bolts holding it in.
    Brake line is probably going to keep the LCA from extending far enough to get the spring out.
    I ended up removing the spindle from both control arms to get the springs out
    Oh and remove the shocks
    Bottle likes this.
  3. Bottle
    Bottle Member
    Been struggling with this for a while now, spindle won't freaking come off, like it's one solid peice with the upper ball joint. Both balljoints unbolted, shock removed, and swaybar disconnected. Nothing connecting these things, been hammering and hammering and ended up destroying the upper balljoint
  4. jetas
    Since you already destroyed the BJ, grab a pickle fork and seperate it that way.
    Were you able to break the lower BJ loose from the spindle?
    90DailyDriven likes this.
  5. 90DailyDriven
    90DailyDriven Veteran
    New Mexico
    90 standard cab 2wd short bed
    I'd put that castle nut back on the upper ball joint. You dont want that spindle jumping towards you when it does release and your hand is in that area.
    the tools made to remove ball joints save you time and money.
  6. Bottle
    Bottle Member
    I didn't know there was a tool for removing ball joints, my other cars had no issues removing them once unbolted. I'll see if I can get one, and I'll throw that nut back on, I didn't even think about that, thanks
  7. Bottle
    Bottle Member
    Thanks foe your help guys, got it yesterday with a pickle fork. New mighty max springs and gas a justs in
  8. jetas
    Did you pull the bump stops?
  9. Bottle
    Bottle Member
    Nah still on, i drove it and havent hit one yet, ill cut em later
  10. jetas
    Post up some pictures if you have any.
    Peter T likes this.
  11. Bottle
    Bottle Member
    I've been trying but it keeps saying file too large
  12. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Use tinypic.com then link them here.
  13. jetas
    That or imgur has been working so far
  14. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    Or resize the photos so they stay with your post forever
  15. Bottle
    Bottle Member
    here you go, resized
  16. jetas
    Looks good. Should polish up those mags
    Bottle likes this.
  17. Bottle
    Bottle Member
    Don't yell at me bro
  18. jrbobbles
    jrbobbles Newbie
    1970 Hilux (RN12)
    Hey Bottle - looks good! Was thinking of doing the same on mine. Did you use blocks to lower the back? What size?
  19. Bottle
    Bottle Member
    3 inch blocks on the rear. got the link to em off someone else post on here
