Easiest way to lower a 85
Discussion in 'Suspension/Chassis' started by wuedo347, Sep 7, 2009.
  1. wuedo347
    wuedo347 Newbie
    dfw
    85 yota xcab
    Okay guys want to know which way is easiest? It will be for a 85 xcab!
  2. IronNam
    lowering springs or blocks, B/J flip and spindles and torsions
  3. wuedo347
    wuedo347 Newbie
    dfw
    85 yota xcab
    thanks do you have any pics of your truck setup with that?
  4. wuedo347
    wuedo347 Newbie
    dfw
    85 yota xcab
    i planned to use blocks or springs and djm lca's!
    is this all i would need guys
  5. IronNam
    I only have spindle mount flip aka BJ flip, and 3" drop blocks.
    so a 1-2/3 drop, something like that.
  6. IronNam
    I have alot to lower... especially up front with my wider fenders... I got alot of room. other than that, still need some recent pics
  7. wuedo347
    wuedo347 Newbie
    dfw
    85 yota xcab
    okay thanks! you think the djm lca's and 3" blocks would be good enough for my 85? i just want a nice little drop
  8. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    I would start with 3" blocks and arms. You can always crank the bars down a bit and take the middle leaf out of the pack. And take off any overload leafs that may have been added. Stock pack has 3 leafs.
  9. IronNam
    Basically that'll get you pretty far.
  10. standardbyker88
    lynnwood, wa
    by saying "i would start..." i mean that as a figure of speach. i usually just dump my trucks in the dirt right off the bat. lol.
    and cin...you gotta drop that thing more. find some cheap used tires and wheels. or atleast ditch the hub caps. itll look good with some simple rims. scion tc stocks will fit nice, even though they need a wheel adapter for the bolt pattern (5x100).
    anyways, post some pictures after you get that 85 started and lowered.
  11. wuedo347
    wuedo347 Newbie
    dfw
    85 yota xcab
    Which bars are you talking about tighting up? Also by pulling a leaf will that make it ride rough?
  12. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    lossen the torsin bars to to relieve the tension in turn lowering the truck, they are the big long bolts on the cross member, and no removing the middle and overload won't cause it to ride rough.
  13. standardbyker88
    lynnwood, wa
    for mine, it actually rode better with the center leaf out. stock was too soft and i always slapped into the overload. middle put set the main onto the overload and therefore made it ride less bouncy. not stiff at all, but a little more than it was.
