Drop spindles?
Discussion in 'Suspension/Chassis' started by josealex1636, Feb 9, 2012.
  1. josealex1636
    josealex1636 Veteran
    Ontario,CA
    83 Toyota Pickup
    I wanted to get drop spindles for my 83 toyota pickup 2wd nd i wanted to know if the drop spindles from a 84 toyota pickup will fit right in?
  2. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    no they won't.
    the 79-83 spindles have both ball joint studs pointing to the ground, while the 84+ have one pointing up and one pointed down. you can fit them by modifying the lower control arms.
  3. josealex1636
    Ontario,CA
    83 Toyota Pickup
    So which ones would u recommend bro?
  4. burnzya
    bodied 73 hilux
    there is only 84+ drop spindles. if you want them you'll have to modify the lower balljoints. i've read of people using the 84+ upper and lower control arms so the spindles bolt right up but if i remember right it widens the track width like 1/2" per side. might be an issue if you're really low.
  5. josealex1636
    Ontario,CA
    83 Toyota Pickup
    Oh alrite forsure thanx I appreciate ur time bro
  6. yankeetaco72
    yankeetaco72 Veteran
    Escondido
    82 short /97 Tacoma
    X2.... Im swapping all the suspension to 84+ on my 82 and eventually getting drop spindles. But for now i can at least do a ball joint flip and get some djm lower arms to strengthen my drop.
  7. josealex1636
    Ontario,CA
    83 Toyota Pickup
    So wat r u getting from the 84?
  8. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    It takes every last piece besides steering components to do the swap.
    And remember to use all the parts from the same truck. Some parts did change around 88-89 and isnt compatible earlier to later. :waytogo:
  9. eastsidevallero818
    eastsidevallero818 Member
    Illinois
    1980 toyota pickup
    So the lower, upper control arm and the spindle from a 84 yota will fit on a 80 cuz I want to lower the front but I'm having trouble finding parts for it all I get is 84+
