drop spindles
Discussion in 'Suspension/Chassis' started by crisis, Dec 9, 2011.
  1. crisis
    crisis Newbie
    grand junction colorado
    80 singlecab 2wd
    i have a 80 2wd and just wanted to see anyone knew if drop spindles for an 84 would work on my 80. im not sure if anything changed between those years. any advice helps
  2. GrantH
    GrantH Addict
    Hattiesburg, MS
    No, from what I know you will need other parts aside from spindles. I think you can fit our BJs in your arms though with some modification and then use the spindles. Contact Bodybagged on here. Pretty sure James has done it.
  3. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    I put drop spindles on my truck.
    Need to swap out upper and lower control arms, radius rods and othe things. And it takes a crap ton of positive camber adjustment.
  4. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    i have drop spindles off an 84-88 at home with top and bottom control arms i believe
