drop spindles side by side with originals
Discussion in 'Suspension/Chassis' started by ryans88yota, Feb 25, 2013.
  1. ryans88yota
    ryans88yota Enthusiast
    olympia wa
    88 2wd base reg cab.
    My search function is not working. I need to see a pic of drop spindles compared to originals. Is it the stub axle thats lifted 2" or is it a combobof stub axle and balljoint mounting points? Im curious cause with my wheel combo I have very little wiggle room from balljoints to rim.
  2. not forgotten
    not forgotten Addict
    Washington
    82 SR5 L/B
    Go to Google images and type in 84 toyota pickup stock spindles and than 84 toyota belltech drop spindles, save the 2 pics and then compare them.
  3. ryans88yota
    olympia wa
    Alright just tried. Its tuff to say. Id like to hear from someone that put em on and if they noticed what it did as far as move the ball joint clearance in lew of the wheel
  4. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    Just the spindle is moved
  5. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Part where yor rotor mountis is moved up 2". Only other thing thatchanges is the part where the tie rod end mounts to the spindle is integrated on the BellTechs...its bolted to a stock spindle..
  6. ryans88yota
    olympia wa
    I gonna assume u mean stub axle. Which means my lower balljoint will be closer to the rim and upper balljoint will be lower than the rim.
  7. NashMan
    NashMan Toyotaholic
    94 2wd
    That is correct
  8. ryans88yota
    olympia wa
    Well I will be unreasonably lucky if my lower control arm clears my wheel. I may be able to unflip my lower bjs to make more room. I already have a 1/4" spacer in the front that helped but we shall see! I have clearance issues with my upper bj now so glad to hear thatll get fixed! Thanks all
  9. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
  10. ryans88yota
    olympia wa
    I am very fortunate u found me aswell I b have not seen that thread and am very greatful u brought it to my attension. Its exactly what I needed to see.
