Drivetrain noise
Discussion in 'Engine/Drivetrain' started by 94Yota_05CBR1K, Jul 15, 2011.
  1. 94Yota_05CBR1K
    94Yota_05CBR1K Veteran
    San Diego aka SD, Daygo. Cali
    94 YoTa Mini 2wd
    Okay so I am experiencing some noise in the drivetrain. Furthermore, it sounds like it is coming from the rear differential. It is a constant sound as long as the truck is moving. Kinda sounds like the sound that comes from off road tires. Anyone ever have the same issue or know what it possible might be? I'm going to service the oil and see if that does any difference. :(
  2. jetas
    When mine did that noise the pinion bearing crapped out.
  3. Beefed Taco
    Beefed Taco Addict
    A whine? A whine is usually the ring and pinion dying. A clicking or grinding is usually a bearing going bad, or being run dry.
    Pull the fill plug immediately, stick your finger in and feel for gear oil. If you don't feel anything, get some 85-90 from your local store in there like yesterday.
  4. jetas
    Is it like a humming sound?
  5. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    either way bearings or ring and pinion that 3rd is gonna have to come out... gl
  6. IronNam
    is your u joint bad? lol I destroyed mine during winter and fixed it in spring time :D
  7. 94Yota_05CBR1K
    94 YoTa Mini 2wd
    Yes it is a whining sound. Oil is full but I think I should change it anyways. Am I better off replacing a different rear diff or any other options?
  8. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    If it's whining, the damage is done and changing oil won't put metal back on the bearings.
  9. Ian Nexus
    Ian Nexus Member
    Torrance CA
    93 xcab 22RE 2WDAuto
    You could just consider it a "feature", my old Lotus Eclat had a whining diferential - when I found a rebuilt unit cost $1000, I purchased an oil addative and put that in with new oil - it made it a little quieter :rolleyes: and kept an eye out for someone parting out another.
    I think the addative was made by "millers" or someone (I dont think it was beer).
  10. 94Yota_05CBR1K
    94 YoTa Mini 2wd
    Would it be a waste of time and money to service the oil when I can put the money into another rear diff?
  11. jetas
    Well u shouldnt need the entire diff, just the 3rd member.
    If the fluid level is low then maybe adding some oil might help.
    Easy way to Check if the pinion bearing is done is to move the driveshaft right at the pinion. If u have lots of movement then ur culpit will be there. Otherwise it aint too hard to pull the 3rd member to inspect it
  12. dillinja666
    sounds like what i just did to a chevy at work. whining fromt he diff on accel and decel, i changed out the bearings and hte noise was still there, after pulling off the cover again ( its a chevy ours dont have a cover, you pull the 3rd member out ) i found a nasty wear pattern on the ring gear, replaced the ring and pinion and the noise was gone. you can get a rebuilt 3rd member for like 500 bucks or go to a junkyard and pull one and inspect it before you buy it. either way dont bother wasting money on changing the fluid, the diff is done, save up and replace the diff and the oil at the same time.
  13. IronNam
    talk to mightymouse if you need somethin'
  14. Enemy of the State
    Enemy of the State Enthusiast
    1985 xtra cab
    If you have to change the 3rd member, you should look into a toyota electronic locking 3rd member that came factory in the 4runners and tacos (pre runners and 4x4). You're in cali so it shouldnt be hard to find one (i've been looking for one for about 2 plus years now). Here is a link with a wealth of knowledge: Erik's Toyota Differential info
  15. 94Yota_05CBR1K
    94 YoTa Mini 2wd
    $500?!? I can get a used rear diff off a buddy for a fourth of that price.
