Driveshaft problem
Discussion in 'Suspension/Chassis' started by enjoi121, Apr 23, 2013.
  1. enjoi121
    enjoi121 Newbie
    ohau, waipahu
    93 single cab
    My 1993 Toyota pickup has drop spindles, drop leaf springs, and 3" drop blocks. I have a problem with the driveshaft grinding on my cross member. Does the taper drop blocks make a difference on the driveshaft?? Lmk ASAP
  2. icpurplepplalot
    icpurplepplalot Member
    Baton Rouge
    94 Base
    Sound like you need to notch the cross member buddy. The angled blocks are just for pinion angle.
  3. Litneon
    Cocoa, FL
    94 xtra cab
    With the drop springs and blocks you'll need to notch the crossmember.
  4. EasNitN38
    EasNitN38 Member
    Ya I had the same issue. Build a notch and weld it in. Mine turned out great
    Have pics if needed
  5. enjoi121
    enjoi121 Newbie
    ohau, waipahu
    93 single cab
    Okay thanks for the info..
  6. enjoi121
    enjoi121 Newbie
    ohau, waipahu
    93 single cab
    @Easnitn38 send me some pic of the cm notch. Did you notch your frame too? If so let see some pics. Wondering how I should do it.
  7. EasNitN38
    EasNitN38 Member
    Pm'd ya some pics bud.
  8. enjoi121
    enjoi121 Newbie
    ohau, waipahu
    93 single cab
    Thanks man
  9. EasNitN38
    EasNitN38 Member
    Did my pics help ya out any?
  10. donellk
    donellk Member
    Palm Bay
    '93 Toyota Pick up
    Same issue here been meaning to do something about it... I'd like to see pics if you can post em on this thread that be dope
