Drilling the headlight
Discussion in 'Exterior/Body' started by Yotaman, Aug 1, 2013.
  1. Yotaman
    Yotaman Newbie
    Hey everyone I got a 95 toyota regular cab with a 94 4runner front end
    Well,I was wondering if you can drill the headlight like maybe about
    1/2 inch hole or will it crack.what I was gonna do was put on some
    City lights but first wanted to get some advise on drilling the headlight
    It's not a sealed beam.you can change the bulb.so can someone pls help
    Me want to get this mod started thankyou
  2. Litneon
    Cocoa, FL
    94 xtra cab
    If it's through plastic or metal, yes. If its through the glass, probably not.
  3. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Wtf is a city light.
  4. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    A small light bulb (194 size) that comes on with your parking lights to slightly light up the headlight housing.
  5. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Well then since the backside of a 4runner headlight is plastic, why not drill it there?
  6. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    I'd just drill it buy a rubber 194 socket lead so it will fit snug and not leak ..
    City lights are from Japan Origins . They got the name city because the city's in Japan are so lite up at night that headlights are not required or needed . And heard that it was mandatory no headlight rule while n the city ..go figure . Sounds kinda sketchy
    I had 95 civic with Japanese head lights plastic
    And they came stock with them as we're the us civic did not and were glass
  7. raylcc
    raylcc Addict
    Denver, CO
    If the housing is glass, there is a glass and tile bit that is sold at hardware stores that might... MIGHT drill it. I used to drill holes in liquor bottles to make... Ahem... Tobacco pipes. :rolleyes:
    However, I should point out that for every one I successfully drilled, there were at least a couple that would shatter on me while drilling. If you choose to go this route, it may be good to have spares in case they break.
  8. Xs5875
    Xs5875 Addict
    Greenville, Ga
    You know what? On my '82 I had I bought some of the H4 upgrade lights where ya can change out just the bulb in the back, and they came with that 194 in there. Pigtail and all. I wondered what that was for. Never even wired it up. Hmmm.
  9. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    I use city light sockets for colored LEDs. Looks cool at night having orange or purple headlight housings. Also works well with an amber bulb on the marker light circuit.
  10. IronNam
    get a 194/168 socket and get an LED in there. It's plastic so take your time doing so, in that way you don't have to cuss trying to get plastic shavings out.
  11. Yotaman
    Yotaman Newbie
    Yup thanks guys helped alot I'm gonna start this mod today.
