Double DIN Headunit for '88
Discussion in 'Interior/Electronics' started by tehsk, Dec 29, 2009.
  1. tehsk
    tehsk Enthusiast
    Northridge, CA
    88 2.4L Carb
    I just picked up a second truck to make in to a clean mini and first thing I wanna do is the sound system. I took a look at Crutchfield to see what will install without a wiring kit and it seems like only single din units will fit. I really want to do a double din unit with a big screen.
    Any of the audio guys run one of those double din units with navi, dvd, ipod, etc?
    Any known models that will install without a fuss?
  2. zukin
    zukin Newbie
    double decks are a direct bolt in as long
    as you have the oem brackets, all you have to do is remove
    pocket.
  3. Darrin87
    Darrin87 Member
    Yulee, FL.
    87 xcab long bed 22r
    Double din's are easy in these trucks, like Zukin said reuse oem brackets. If you dont have them and you order from Crutchfield, you can get the brackets from them. For DoubleDin HU I like eclipse, AVN 726E, great features, plenty of options and easy to use.
  4. tehsk
    tehsk Enthusiast
    Northridge, CA
    88 2.4L Carb
    Thanks for the feedback zukin and Darrin87, I'm going for the ECLIPSE AVN6620. Do you know if I'll need to a get a wiring harness to get it installed?
  5. trap
    trap Addict
    orange county ca
    92 pickup
    if you want a awesome touch screen/radio for the money get a pioneer avh-p4100. If you want navigation I like the new pioneer avic z110 alot. I have installed multiple motorized double din radios in my truck and they have all fit perfectly.
  6. Darrin87
    Darrin87 Member
    Yulee, FL.
    Yes you will need a harness (metra # 71-1761). also if you want to watch video while driving on that model radio take the parking park wire and connect it to either the ground wire in the harness or screw it to bare metal, that will by-pass the safty feature and let you use all the functions while driving.
  7. 89dlx47
    89dlx47 Veteran
    st. louis
    89 standard 2wd
    i just picked up a used boss double din. (cant remember the model number right now) and the screen is alittle bigger than the opening in the dash but the screen is huge and its full touch screen which is wat ive been looking for. i just wish it had navigation on it but for 100 i couldnt pass it up. ill post some picks up wen i get my dash back together
  8. IronNam
    OEM brackets ftw
    HU changing is very simple
  9. Chucky
    Chucky Enthusiast
    Southern Louisiana
    88 pickup reg cab,82 sr5 long bed,93 reg cab sr5
    Im going switch to double din too, i already went through various head units,
    first was a stock toyota tape player,went got a ,old pioneer,then a panasonic cq-c8100u, then i went with an aiwa, 180w,, then i finally could afford a 3.5 in dvd, went thorugh 2, still new, and now i got a touch screen,.that come out a single din, but now going to get a double din
  10. Chucky
    Chucky Enthusiast
    Southern Louisiana
    heres what i have in now, its a flip out
  11. SkeeloG88
    SkeeloG88 Enthusiast
    Tennessee
    88 reg cab
    I need own brackets...
