just a little info for you .. the V6 one will work , but you need to change a few things .. I used an 84 2wd lower steering colum shaft , and the 1999 DD booster as well as the /99 clutch master . check out my Trekker build .
So theres a clearance problem with the V6 dd booster on a 2wd?Ive fit em on 4x4 plenty of times.I have one from a 1 ton I may be able to let go I just need to make sure I have a back up for my stout.Can't fit a single booster on the stout, its bigger in dia. and its a feaken small engine bay. Let me look for ya.
