Does a 89-91 grille fit a 88 2WD ?
Discussion in 'Exterior/Body' started by 22R88, Dec 15, 2011.
  1. 22R88
    22R88 Veteran
    South Louisiana
    1988 Reg Cab Deluxe RN50
    Does the 89-94 Grilles fit direct on a 88 front end ? Both 2wd ?
    What about 4wd grilles of the same would they bolt right on ?
    22R88
  2. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    No slight modification needed Im not certain the extent of the modification but I can say its not direct bolt on in either case 2wd or 4wd. But it would make a very nice modification. I think Craigdbl ??? another user did a similar swap.
  3. Byronics
    Byronics Veteran
    Hilo, Hawaii
    89' Single cab
    i've seen it done... iBelieve most of the tabs will line up on the radiator support but im not to sure how the corner lights fit.
  4. Hale On Wheels
    Hale On Wheels Enthusiast
    Shasta Lake City, Nor Cali
    84 X-Cab
  5. luckysevens808
    luckysevens808 Newbie
    I put a 91 grille on my 86 the outermost tabs on the bottom are perfectly in the way of the bottom screw which holds/directs your lights. So I just sawed those off as close to the base as I could. The top tabs pretty much do line up, like previously stated. I'm using zip ties to hold this grille on though cuz all my stock tabs are broken/lost. Can't even tell though and it looks sweet.
