do u know if these will fit
Discussion in 'Wheels/Tires' started by layedout94, Jan 11, 2011.
  1. layedout94
    layedout94 Enthusiast
    aberdeen
    94 toyota hilux
    Im lookin at some lexus 18s there 8 inches wide in front and 8.5 in the back.. The only concern I have is that the rim on the front driverside will hit my steering rod when I have the truck layed out does anybody know
  2. jctoy29
    jctoy29 Addict
    surprise,az
    Sounds like the 2nd gen IS wheels, your are most likely gonna have run a spacer or wheel adapters due to the IS positive offset and smaller center bore.
  3. layedout94
    aberdeen
    94 toyota hilux
    Alright how big of spacer would I need... and sorry not worried about the rim hittin imctualy concerned about the upper control arm hittin will it camber too hard im runnin steelies no and it rubs when layed out... do u know a cure for this
  4. layedout94
    aberdeen
    94 toyota hilux
    Does any body have a pic of therer rig with these rims there lexus 18 inch aluminum staggered 5 spoke
  5. thundering02
    thundering02 Addict
    Fenton 63026
    Find the offset for those rims for further assistance.
  6. macawilial
    macawilial Veteran
    Born and raised in San Diego
    I believe these are the same offset
    Can't recall the offset but they did fit. Same size and stagger too. When I first had them on, I had to bore out the centers to fit (from 60.06 to 67.06mm). Before the notch was done, Very slight rubbing issues seen at the back. It was rubbing the ends of the crossmember just above the axle. Since you are bagged, this shouldn't effect you. Up front The only real problem I had was that the upper ball joint zerk fitting was scoring the inside of the rim. I ended up unscrewing the fitting and just plugging them up. Saved them for regreasing. I eventually added half inch spacers up front for better turning radius but that's up to you.
    Sorry I don't have any clearance shots. Pictures are old.
    Hope this helps and good luck
  7. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Macawilial your truck is sick. Still running the 6/6 drop?
  8. macawilial
    macawilial Veteran
    Thanks
    No, I've actually been bagged for about 2 years now. I'm in the process of buttoning up a body drop on this now. It's been almost a year now on that. I plan to have her finished with paint and body by the end of this year though.
  9. layedout94
    aberdeen
    94 toyota hilux
    YUp those r the same rims thanks.. How much did u pay for them.. They want 240 for the set... just makin sure im not over paying
  10. macawilial
    macawilial Veteran
    240? Sounds like a good deal!
    Even better if the tires on them are still good. I paid an additional 80 bucks for the center boring the 4 wheels(60 for the boring and another 20 for rebalancing)
    Nice find!
  11. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Thats a pretty good deal if it comes with tires with some thread.
  12. patrickgraven
    patrickgraven Veteran
    Corona CA
    93 2wd pickup "home depot" / 2004 Toyota Sequoia 4x4
    Where did you have the, center bored out. Im looking at a set of those for my 93.
  13. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    Wow in the valley i found 1 rim for $200.
